[mapguide-internals] RE: PATCH: Raster stability fixes,
ticket#462
Frank Warmerdam
warmerdam at pobox.com
Sun Mar 29 17:09:29 EDT 2009
Haris Kurtagic wrote:
> Yes, I am aware of that, I write that in my first email. But, still it
> is semi fix. Depends when you reach pool size.
> GDAL is not thread safe ( when I looked at source code more then year
> ago it was not). According to Frank with 1.6 multithreading is yet to be
> confirmed/tested, I hope Frank will comment this.
Folks,
It is intended that read-only access should be thread safe in GDAL as long
as each thread is using a distinct GDALDataset object (not sharing a single
one). However, it is difficult to *prove* threadsafety in C++ applications
and it is likely that there are some holes in it in GDAL.
I would like to see the "big lock around GDAL" be something that can be
easily turned off for those willing to take a bit of risk, and do some
testing for their use case and want to get maximum performance. However,
I'm a bit nervous about shipping MapGuide and the FDO GDAL provider in
a way that completely trusts GDAL's thread safety.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
More information about the mapguide-internals
