[mapguide-internals] mgos 2.1 state Build on CentOS5 Problem
with JavaApi
UV
uvwild at gmail.com
Mon May 4 23:20:23 EDT 2009
Hi Warren,
my Centos build fails trying to build the JavaApi project (I think also
using swig)
Some include paths to the JNI are not setup correctly and I cant find
any useful pointers.
Can you find anything in your working build that could help me?
That would be greatly appreciated as the haystack is quite massive ....
a copy of your make output/ build log could be helpful .... or the
configure output from the JavaApi project.
Basically where does your build take the JNI includes from or how is it
installed?
I am building from trunk on an CentOS5.2 virtual machine.... working
fine generally ..
most of MapGuide is done already....
but there are little bits and pieces of configuration info missing on
the way.
Cheers,
UV
Stout, Warren wrote:
> Well, I've have pretty good luck with compiles on CentOS(rhel) than anything else. I have recently started more in depth on openSuSE as that's what I've used for years.
> I agree that many have probably been scared away from Linux trying to get builds to work. Most of the fixes I've done are pretty simple to get the builds to work on newer compilers. But as I was saying, I've having a hard time getting FDO for PostGIS and Oracle working correctly. The SDF and SHP have been pretty solid and performance is much improved over older versions.
> Some folks at Autodesk have suggested a few times I get more involved in this. But I've had very little time this year because of other projects. Perhaps I can lend a hand in a month on wiki, etc. Who would I contact about contributing to that?
> Thanks for the replys to both you and Jason.
> Warren
> ________________________________________
> From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
> Sent: Monday, May 04, 2009 6:01 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] mgos 2.1 state
> We really need to get the linux stuff going :) the current state is terrible,
> so many people have wasted so much time trying to build mapguide on
> linux and failed, i think we have lost heaps of potential users because of this
> It would really help if we move any updated build instructions over to the
> mapguide wiki, rather than the osgeo wiki...
> anecdotally based on what i have seen on the mailing list, there seems to be
> a bigger demand for ubuntu than RHES/Centos
> z
> On Tue, May 5, 2009 at 10:53 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
>> To my knowledge, 2.1 is no less stable than any previous version at this point, and is considerably improved in many areas. If I was going to start on a new project I would absolutely be looking at 2.1.
>> A few bug fixes have recently made it into 2.1 because of the delays in getting our installer put together, but those are just a bonus; 2.1 was feature-complete several months ago.
>> Jason
>> From: alucas
>> Sent: Monday, May 04, 2009 10:54 AM
>> To: mapguide-internals at lists.osgeo.org
>> Subject: [mapguide-internals] mgos 2.1 state
>> I'm planning a new project and i'm thinking in mgos 2.1. What's the state of
>> this version? What are the bugs pending to solve?_______________________________________________
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
> NOTICE: The information contained in this electronic transmission is
> intended only for the use of the individual or entity named above. ANY
> DISTRIBUTION OR COPYING OF THIS MESSAGE IS PROHIBITED, except by the intended
> recipient(s). Attempts to intercept this message are in violation of 18
> U.S.C. 2511(1) of the Electronic Communications Privacy Act, which subjects
> the interceptor to fines, imprisonment and/or civil damages. If you are not
> the intended recipient(s), please delete it and notify me.
More information about the mapguide-internals
