[mapguide-internals] Commit rights for UV
Zac Spitzer
zac.spitzer at gmail.com
Thu May 7 23:45:22 EDT 2009
that plugin looks like a great idea! it's good for capturing the knowledge
as well for new developers to get involved.
Jason mentioned that we can do the sandbox only commit access,
it's just a simple enough change to the svn acl file which is basically
you define a group and assign it RW to a svn folder
z
On Fri, May 8, 2009 at 1:40 PM, Trevor Wekel
<trevor_wekel at otxsystems.com> wrote:
> I wonder if an online code collaboration tool would be of benefit to
> MapGuide and OSGeo. Even developers with commit rights should be getting
> code reviews from other developers. We do this internally at Autodesk but
> there is currently no mechanism to do this easily with the external
> community. There is a "trac hack" available which might be appropriate.
> http://trac-hacks.org/wiki/PeerReviewPlugin
> I don't know if it is possible to grant commit rights to the sandbox only.
> It would make the commit rights approval more transparent if code could be
> checked into sandbox and then reviewed. If not, perhaps we can simply add
> the code review comments to the tickets which contain the patches.
> Thanks,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
> Sent: Thursday, May 07, 2009 8:28 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Commit rights for UV
> Currently, the process is only poorly defined and does not state very
> clear rules in particular in regards of timing.
> Can someone jump in (from the PSC i guess) review my code and provide me
> some feedback, I've been working on this for a while now and I would
> like to know how close I am to getting commit rights?
> The several patches requirement is a little loose, as for RFC60 there is
> one big patch, which could be seen as a equivalent to several smaller
> patches? And there are other contributions regarding other issues which
> show further insight into the server code.
> Zac Spitzer wrote:
>> Just been reading the PSC notes, sorry I couldn't make the session,
>> waaayy to late down under..
>> I am rather worried about the trend that UV after posting a RFC
>> and then actually implementing it, plus his work on the build stuff
>> plus numerous other small issues he delved into and has found
>> solutions for, still isn't being considered for commit rights as
>> per the notes from the PSC...
>> How high is the barrier for entry? Where are the PSC members
>> actively supporting new developers and guiding them into moving
>> forward to commit status.
>> This seems to of happened with both Helio and UV, both have stepped
>> up, dived deep into the code base but are still 'locked out'
>> I think the PSC needs to be way more active in this regard if MapGuide is
>> going to succeed as an open source project.
>> Initially with UV, the feedback from the Autodesk team was that they
>> where reluctant to guide new developers until they proved their
> commitment.
>> There is a certain level of irony in the PSC notes, where on one hand it
>> has been said that UV is not ready for commit rights, but at the same
> time, he
>> has done the work on working out failed tiled stuff which was no minor
> effort
>> in itself and the PSC then suggesting that he should write a RFC for it..
>> That seems rather contradictory.
>> Moving forward, can I ask for someone in the PSC take a direct involvement
>> in regards to commit rights for UV?
>> z
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
