[mapguide-internals] Another installer test...
Jason Birch
Jason.Birch at nanaimo.ca
Tue May 12 19:11:12 EDT 2009
cagray wrote:
> I have used the 0.6 installer on Vista (32bit) using .NET and it works
> fine as far as i can see. One minor point is that there appears to be a
> mistake entry in IIS. The mapviewernet folder is pointing to:
> MapGuide Web\www\....
> instead of:
> MapGuide\Web\www\....
Was that on a machine where you'd installed a previous installer test? I
tried the installer on Server 2008 again with the .Net option, and
mapviewerajax was mapped to the correct location. IE, I can't duplicate the
problem...
View this message in context: http://n2.nabble.com/Another-installer-test...-tp2776791p2875437.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
