[mapguide-internals] RE: Another installer test...
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Wed May 13 14:01:52 EDT 2009
Not intentionally, I belive it is a regular clean install.
Regards, Kenneth Skovhede, GEOGRAF A/S
Jason Birch skrev:
> That's interesting...
> Is your main site set up that way too?
> ----- Original Message -----
> From: mapguide-internals-bounces at lists.osgeo.org <mapguide-internals-bounces at lists.osgeo.org>
> To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
> Sent: Wed May 13 00:46:06 2009
> Subject: Re: [mapguide-internals] RE: Another installer test...
> After installing on Win 2K3 R2, with IIS ASP.Net,
> the mapagent has "integrated authentication" enabled, which causes all
> requests to be denied (authentication failed).
> I'm not sure why that is enabled, or if its fixable in the installer.
> Jason Birch skrev:
>> Oh...
>> I forgot to say that this build also includes:
>> - Trevor's recent fixes for the HTTP connection
>> - Bruce's fixes for the fdo connection problems (mostly evident in GDAL)
>> - Walt's optional optimizations for dealing with thick lines
>> Lots of goodies in there to look at when you get a successful install. If you've been having stability problems, this is definitely worth trying out.
>> Jason
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
