[mapguide-internals] Getting the map extent in meters/feet and converting coordinates
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed May 13 16:16:40 EDT 2009
I have the code ready for issue #768
http://trac.osgeo.org/mapguide/ticket/768
But, the coordinates should be converted into WGS84.
I would really like to keep CSMap/Proj.4 out of the Maestro project.
I can't find a documented function that would allow me to perform a
projection conversion through the mapagent.
Is there an undocument function somewhere that I can use?
For the MgCooker, I am trying to get the map extent in meters.
That would also be avalible through the projection libraries,
but can I access it from the mapagent?
Regards, Kenneth Skovhede, GEOGRAF A/S
More information about the mapguide-internals mailing list
