[mapguide-internals] detecting dangling feature readers
Walt Welton-Lair
walt.welton-lair at autodesk.com
Sat May 23 02:45:30 EDT 2009
Just to clarify, it's technically not a leak - the reader's destructor does call Close. The problem occurs ifyou use .NET code in your web tier. The managed readers in the web tier don't get garbage collected right away, and this can lead to a buildup of cached readers on the serve (this was the "leak" reported in the ticket). Once GC kicks in the web-tier proxy readers are destroyed / closed, and this also cleans up the corresponding readers on the server.
Nevertheless, it's still good practice to call Close as soon as you're done with the reader. I don't know of any API which can enumerate the open readers.
Walt
________________________________________
From: mapguide-internals-bounces at lists.osgeo.org [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer [zac.spitzer at gmail.com]
Sent: Friday, May 22, 2009 11:58 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] detecting dangling feature readers
just following up on this ticket
http://trac.osgeo.org/mapguide/ticket/989
it's there any method available to enumerate open readers
to detect these kind of leaks?
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
