[mapguide-internals] Initial RC1 Build?
Crispin_at_1Spatial crispin.hoult at 1spatial.com
Wed Nov 4 04:01:49 EST 2009
Jackie,
As is implied in Kenneth's reply, it is not the reboot that is the problem -
I can schedule that and cope with the need.  Why reboot?... IISRESET picks
up most changes - is it the service needing the PATH change for CS-Map?  I
would have thought this was picked up on the service restart...
Anyway I digress... the issue with the RC1 installer is that there is no
warning or option, at the end of the install process the reboot kicks in.
You can sneakily leave an edited TXT file open in notepad to force a user
interface catch but ideally the installer should ask/warn.
Thanks - Crispin
Jackie Ng wrote:
> I've been thinking about this required reboot, and was wondering...
> How did installers pre-2.1 (2.0.x, 1.2, etc) get away without rebooting?
> Didn't they set a system environment variable as well (for Proj.4)?
> - Jackie
> Crispin_at_1Spatial wrote:
>> Hi - just to bring this up before the PSC meeting.
>> I have been using this version (2.1.0.4283-RC1.exe) in our classic .net /
>> IIS environment for a while now and looks good.
>> At the last meet there was to be a release before the end of October -
>> **please** follow the guidelines and launch 2.1 so that the effort can
>> move on, it's quite painful from this end you know...
>> The only thing is the installer does the rather harsh forced reboot at
>> the end without warning that on server environments is not ideal.
>>  Crispin
>> Jason Birch wrote:
>>> Hi all,
>>> Well, I got the build done, but did not get to do ANY testing on it; ran
>>> out
>>> of time if I want to be functional at work tomorrow.  Have uploaded
>>> here:
>>> http://download.osgeo.org/mapguide/testing/
>>> as: MapGuideOpenSource-2.1.0.4283-RC1.exe
>>> And the md5sum output is:
>>> c85fad1a8410988b37099ac307ca8b0f *MapGuideOpenSource-2.1.0.4283-RC1.exe
>>> Please try installing (on a non-production machine) if you have a few
>>> minutes, and once we get some hopefully positive notes we can move it
>>> into
>>> the release folder for 2.1.0.
>>> I was hoping to roll FDO 3.4.1 RC1 into this release, but fate was
>>> unkind :)
>>>  I did swap the SQLite provider for Traian's back-ported 3.4 version; if
>>> anyone has concerns with this I can put the original version back in,
>>> but it
>>> has some nasty bugs.
>>> Jason
>>> mapguide-internals mailing list
>>> mapguide-internals at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Initial-RC1-Build-tp3767422p3943871.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
