[mapguide-internals] Server Font Queries
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Sat Nov 7 07:46:32 EST 2009
Thanks Walt,
I assumed it was something like that. Font matching is OK for text/labels
but would result in completely different symbology being displayed for font
symbols that are more typically a character code in WingDings etc (though
the legend would match of course).
So back to authoring - should there be a way for the MG server to expose
it's known fonts through the API for clients such as Studio/Maestro to
understand?
Walt Welton-Lair wrote:
> The Freetype library gets initialized at startup, and then the server
> loads all fonts in the system font folder. Once the server is running it
> does not check again for new fonts.
> There's probably some optimization that can be done here, e.g. lazy
> loading of fonts. But in the case of your Asian font, if we don't load it
> at startup and instead load it on demand, then when a layer using that
> font is stylized it will take an extra 30 seconds (on your server) the
> first time. That doesn't make for a good user experience.
> Also keep in mind that stylization supports font matching - if a specified
> font is not found then it iterates through the available fonts looking for
> a reasonably close one. At that point the server will have to load all
> the fonts. So it's a tradeoff. Is it better to load them all at the
> beginning, at a time when no users are active? Or load them on demand,
> forcing users to wait longer the first time they make a request which uses
> an unloaded font?
> Walt
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of
> Crispin_at_1Spatial
> Sent: Friday, November 06, 2009 6:18 AM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] Server Font Queries
> Folks,
> For MapGuide text and font symbols the definition of the font is contained
> in the layer XML.
> When authoring layers in Maestro there is a hard-coded set of fonts from
> an
> XML file. These are pretty standard but limits flexibility, especially
> when
> dealing with symbol fonts that may have been loaded on to the server. Is
> there a way through the MapGuide API do do font discovery?
> Finally, I noticed on a low-powered server that at MG service start-up
> (using FileMon) there was a huge amount of font polling. A couple of
> Asian
> sets (Batang) took 30+ seconds of MG server processing.
> Crispin
> http://n2.nabble.com/Server-Font-Queries-tp3958112p3958112.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
View this message in context: http://n2.nabble.com/Server-Font-Queries-tp3958112p3964019.html
More information about the mapguide-internals
