[mapguide-internals] 2.1.0 Final Windows Installer
Jason Birch
jason at jasonbirch.com
Wed Nov 25 12:04:13 EST 2009
The installer requires that the default website still exists; for IIS6 this
means that both the internal ID and name are unchanged from the default.
IIS7 I think only requires that the name is available. The important
variables are SITE_ID and MG_WEBSITE:
http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Installers/MapGuide/MapGuide.wxs#L51
Which are used in:
IIS6:
http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS.wxs
IIS7:
http://trac.osgeo.org/mapguide/browser/branches/2.1/Installer/Libraries/MapGuide%20Web%20Extensions/IIS7.wxs
If you have renamed or deleted the default site, the installation will fail.
One of the wishlist items for the installer is a dropdown of websites to
choose from, but it will require some development work.
In the meantime, you can perform a manual install, and configure the IIS
integration manually. This is a bit of a pain; perhaps we should look at
setting up some scripts that could be easily edited and run by users for
this...
Jason
2009/11/25 Simon Pelicon
> Hi!
> I have issue with new installer on Windows Server 2003 and IIS 6.0.
> Installing with IIS configuration and PHP fails with message: Failed while
> processing WebVirtualDirs.
> Any thoughts?
> Simon
> On Mon, Nov 23, 2009 at 6:52 PM, Rock Beans <rockbeans at gmail.com> wrote:
> > Nice work on the new installer by the way. It seems to eliminate many
> > of the setup issues we have had.
> > On Wed, Nov 18, 2009 at 12:45 AM, Jason Birch <jason at jasonbirch.com>
> > wrote:
> > > Hi all,
> > > I've uploaded what I hope is the final 2.1.0 windows installer:
> http://download.osgeo.org/mapguide/releases/2.1.0/MapGuideOpenSource-2.1.0.4283-Final.exe
> > > MD5 (also attached):
> > > f5b86032f72f242329450b16634abba7
> *MapGuideOpenSource-2.1.0.4283-Final.exe
> > > This _should_ be equivalent to the RC, but with different "branding" in
> > the
> > > installer.
> > > Could someone please announce, update web pages, etc? Make sure to
> > mention
> > > that to install on 64bit IIS, user will need to manually set their app
> > pool
> > > to 32bit mode.
> > > I've tested this install on W2k3 and it appears to install and load
> > > mapagent/mapadmin fine.
> > > I don't think we have an answer for Linux users other than SVN, which
> can
> > be
> > > painful at times.
> > > Jason
> > > _______________________________________________
> > > mapguide-internals mailing list
> > > mapguide-internals at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
