[mapguide-internals] Does the Select Within only work for polygon
Buddy Hu Buddy.Hu at autodesk.com
Mon Nov 30 19:48:46 EST 2009
Hi Dave,
Do we have any specs or something to describe the SelectWithin feature?
Thanks,
-Buddy
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Tuesday, December 01, 2009 12:24 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Does the Select Within only work for polygon
SelectWithin should work with a polygon or multi-polygon. Whether or not the logic is clean enough to handle a case where more than one type of feature is selected (a polygon and a line for example) is another question.
The 500 error is a bug for sure.
Regards,
Dave
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Buddy Hu
Sent: Monday, November 30, 2009 1:22 AM
Thanks Kenneth!
I think so. It seems that there are some logic error for the selectwithin.php.
Any other comments?
Regards,
-Buddy
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Kenneth Skovhede, GEOGRAF A/S
Sent: Monday, November 30, 2009 4:22 PM
Subject: Re: [mapguide-internals] Does the Select Within only work for polygon
It sounds a like a bug to me.
At least there should not be a "500" error.
Regards, Kenneth Skovhede, GEOGRAF A/S
Buddy Hu skrev:
> Hi There,
> I notice that, the Select within only works for polygon. If there are some other features (such as multipolygon, polyline) selected with polygon, there will be a 500 internal Server Error for selectwithin.php. If there are only multipolygon selected, everything will be cleared after I press the "Done" button.
> I find a description about the "Select Within" in the AJAX Task list home page like this: After you have selected an area, such as a buffer or a polygon on the map, you can select certain features within that area.
> So I want to know, does this Select Within function only work for polygon or buffer? Is this intended?
> If it's no, I want to log a defect for this issue.
> Thanks,
> -Buddy Hu
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
