[mapguide-internals] RE: mapguide-internals Digest, Vol 34,
Issue 15
Badreddine Karoui
badreddine.karoui at autodesk.com
Mon Oct 19 15:02:59 EDT 2009
Harris,
You should be able to pin more than one connection per session. The new API takes a feature source id and an application can create any number of those ids and pin their associated connections. My understanding is that the server will keep track of the association between (session,fsdid,connection). Even though the a fsid may refer to the same connection parameters as an existing fsid, if PinConnection is called using the new fsid, then a new connection will be pinned. Of course, you can have a third fsid to the same data and decide not to pin the associated connection. In that case you just grab a connection from the pool as you do today. I assume that pinned or not, the connection will stay around if a reader is still using it.
Badreddine
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Monday, October 19, 2009 10:30 AM
To: 'MapGuide Internals Mail List'
Subject: RE: [mapguide-internals] RE: mapguide-internals Digest, Vol 34, Issue 15
Leaf, UV,
To be able to use only one "pinned" connection in session is unnecessary
restriction to application.
I think UV comment was correct that this RFC is connected to RFC78 (thanks
UV to pointing it out).
Instead of adding parameter to set transaction in execute sql functions it
should be better to use connection as parameter.
On that connection transaction is started or not, which depends of'course on
application.
In such case you can any number of transaction, readers, "pinned"
connections whatever.
Application is in control how and for what wants to use them. In that case
there is no confusion what is pinned what is in transaction etc...
Haris
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Leaf Li
Sent: Monday, October 19, 2009 9:28
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] RE: mapguide-internals Digest, Vol 34, Issue
15
Hi Haris,
Thanks for your feedbacks. I add my comments in lines.
>Sorry if I am late, I have concerns regarding this RFC. What would happen
if
>there are more pinnes in one session or more connections wanted to be run
in
>same session ? Also, If I remember correctly there is link between reader
>being closed and connection released ? If that is case what would happen in
>case of multiple readers?
[Leaf] Two pinned connections aren't allowed to created in one session. Once
users call PinConnection(), this method do nothing when calling it again
till
calling UnpinConnection or pinned connection is time-out.
>In my opinion better solution would be to be able to "get" connection from
>server and then use that connection. In such way user would be able to have
>any number of connections and use them in any way.
>Also that looks to me like cleaner and more understandable solution.
[Leaf] Yes. It can be a solution. To a certain extent, it is cleaner. To a
Certain extent, it may result in some confusing. We have to overload most of
feature service methods to add a new parameter 'MgFdoConnection'. Users can
use pinned connection and unpinned connection in the same time. If users
forget to use the pinned connection in a situation where a pinned connection
should be used, it is difficult for users to debug what's wrong with the
application.
Thanks,
Leaf Li
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
