[mapguide-internals] Issues with MapGuide 2.1 and MrSid...
Martin Morrison
martin.morrison at edsi.com
Tue Oct 20 12:32:33 EDT 2009
Installing the ECW dlls on a test server fixes the error about not finding them but it does NOT fix my MrSID display issue.
If I remove the MrSID layer from my map so it only contains one layer pulled from SQL Server (simple test map) and remove the ECW dlls, it works as expected, no errors. If I add the MrSID layer back in, it prompts me about the ECW dlls. So whenever a SID file is called it looks for ECW dlls. WHY????
Martin
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: Tuesday, October 20, 2009 10:53 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Issues with MapGuide 2.1 and MrSid...
Running the server from the cmd line gives me errors about not finding the ECW dlls. I'm not using ECW, I'm using MrSID. Has the requirements changed so you are now required to load the ECW dlls to get MrSID working? If so, that is a problem. According to their documentation, ECW requires royalties.
Martin
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jonathon
Sent: Monday, October 19, 2009 5:13 PM
To: 'MapGuide Internals Mail List'
It is foggy, but perhaps try copying the lti_* files to the X:\Program
Files\OSGeo\MapGuide\Server\fdo directory.
If you run mg from the command line, it will tell you if it finds the dll
when you try to publish it.
Morrison
Sent: October 19, 2009 1:59 PM
It's not the index. I should be able to place a single MrSid in a directory
and point to it and have it display. I can't do that. It may be that the
directory the dll's need to be in has changed between 2.02 and 2.1. If it
has, it needs to be noted. I have MrSids working under 2.02, I have to
believe something has changed. The fact that you said you copied them...we
simply need to figure out where.
Martin
Sent: Monday, October 19, 2009 4:17 PM
Hi Martin,
I was able to get SID files working on a client site. Unfortunately, I
don't have access to it anymore so I can't tell you the exact directory that
the dlls needed to be under but as I recall, I ended up having to move them
to a different directory.
Opening MG in debug mode was very helpful in finding out whether or not MG
was finding the DLLs.
I found, as I have many times, that the config/index files were not being
built correctly. They end up with 100000,-100000 in the values. I am not
sure what causes this. Ultimately, we have created an FME script that will
generate the proper values. In this case though, I was able to use the
config files from 1.2 and just modify the value of the directory and version
of FDO.
Hope something here helps,
Jonathon
Morrison
Sent: October 19, 2009 10:03 AM
Subject: [mapguide-internals] Issues with MapGuide 2.1 and MrSid...
Having trouble with MapGuide 2.1 RC1 and MrSid files. The first install I
did was to a Windows 2003 server to a non-standard directory
(G:\Gis_Sites\blah\blah\). Could not get MrSids to work. I could get Tiffs
and Jpegs to work so I don't think coordinates are an issue. Just for grins
though, the map and the images are both in the same state plane zone...
AutoCAD Map shows the files placed perfectly. I did a second install on a
Vista (32_bit) laptop, accepting all of the defaults for paths etc. Same
result. Both install were using the bundled config with Apache as the
webserver. I read Jason's posting about MrSid and ECWs.
(http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg10886.html)
Below is a dir listing of where the files are placed and the date/time
stamps. Please ignore the fact that it says Drive X, it is actually the C
Drive of the machine I'm testing with. Anybody see what the issue is? Are
there dependencies that have been left out of the install? Prerequisites
I'm missing? Wrong version?
I don't mind having to load some files (MrSid dll's) due to licensing
concerns, but we do need to make it fairly painless for the server guys to
setup. Jason's writeup would be fine as long as it works. I have a feeling
there is something else missing, or I'm just blind...
Thanks,
Martin
*********************************FILE
LISTING********************************************
Volume in drive X has no label.
Volume Serial Number is 7005-B438
Directory of X:\Program Files\OSGeo\MapGuide\Server\bin
10/19/2009 10:43 AM <DIR> .
10/19/2009 10:43 AM <DIR> ..
10/04/2009 11:05 PM 1,076,224 ACE.dll
10/04/2009 11:41 PM 176,128 dbxml.exe
10/04/2009 11:41 PM 12,288 dbxml_dump.exe
10/04/2009 11:41 PM 11,776 dbxml_load.exe
10/04/2009 11:17 PM 8,704 db_archive.exe
10/04/2009 11:17 PM 9,728 db_checkpoint.exe
10/04/2009 11:17 PM 11,776 db_dump.exe
10/04/2009 11:17 PM 14,848 db_hotbackup.exe
10/04/2009 11:17 PM 22,016 db_load.exe
10/04/2009 11:17 PM 9,728 db_recover.exe
10/04/2009 11:17 PM 9,216 db_upgrade.exe
10/04/2009 11:18 PM 9,728 db_verify.exe
10/04/2009 11:27 PM 974,848 gd.dll
10/19/2009 10:41 AM <DIR> gdalplugins
10/04/2009 11:17 PM 1,011,712 GEOS.dll
10/04/2009 11:06 PM 869,888 libdb45.dll
10/04/2009 11:27 PM 1,496,576 libdbxml23.dll
11/28/2008 03:52 PM 1,650,688 lti_dsdk_cdll.dll
11/28/2008 03:52 PM 1,859,584 lti_dsdk_dll.dll
10/04/2009 11:30 PM 603,136 MgFoundation.dll
10/04/2009 11:44 PM 1,748,480 MgGeometry.dll
10/04/2009 11:42 PM 119,296 MgGwsCommon.dll
10/04/2009 11:49 PM 408,576 MgGwsQueryEngine.dll
10/04/2009 11:29 PM 32,768 MgGwsResource.dll
10/04/2009 11:50 PM 839,680 MgMapGuideCommon.dll
10/04/2009 11:29 PM 272,896 MgMdfModel.dll
10/04/2009 11:30 PM 434,176 MgMdfParser.dll
10/04/2009 11:49 PM 521,728 MgPlatformBase.dll
10/04/2009 11:50 PM 1,824,256 MgRenderers.dll
10/04/2009 11:53 PM 248,320 mgserver.exe
10/04/2009 11:52 PM 291,840 MgServerAdminService.dll
10/04/2009 11:50 PM 71,168 MgServerBase.dll
10/04/2009 11:50 PM 79,872 MgServerCache.dll
10/04/2009 11:52 PM 984,576 MgServerDrawingService.dll
10/04/2009 11:51 PM 1,469,952 MgServerFeatureService.dll
10/04/2009 11:52 PM 163,328 MgServerKmlService.dll
10/04/2009 11:50 PM 853,504 MgServerManager.dll
10/04/2009 11:52 PM 360,960 MgServerMappingService.dll
10/04/2009 11:52 PM 205,312 MgServerRenderingService.dll
10/04/2009 11:51 PM 2,273,792 MgServerResourceService.dll
10/04/2009 11:52 PM 279,552 MgServerSiteService.dll
10/04/2009 11:44 PM 12,800 MgServerThread.dll
10/04/2009 11:51 PM 133,120 MgServerTileService.dll
10/04/2009 11:47 PM 625,664 MgStylization.dll
10/04/2009 11:54 PM 1,885,696 MgUnitTesting.dll
10/19/2009 12:29 PM 27,424 serverconfig.ini
10/04/2009 11:08 PM 1,831,936 xerces-c_2_7.dll
10/04/2009 11:23 PM 2,624,512 xqilla10.dll
47 File(s) 30,463,776 bytes
Directory of X:\Program Files\OSGeo\MapGuide\Server\bin\gdalplugins
10/19/2009 10:41 AM <DIR> .
10/19/2009 10:41 AM <DIR> ..
10/19/2009 10:40 AM 266,240 gdal_ECW_JP2ECW.dll
10/19/2009 10:40 AM 81,920 gdal_MrSID.dll
2 File(s) 348,160 bytes
Total Files Listed:
49 File(s) 30,811,936 bytes
5 Dir(s) 53,645,303,808 bytes free
Directory of X:\Program Files\OSGeo\MapGuide\Server\fdo
10/19/2009 10:42 AM <DIR> .
10/19/2009 10:42 AM <DIR> ..
04/20/2009 08:32 AM 39,424 boost_date_time-vc90-mt-1_34_1.dll
04/20/2009 08:33 AM 40,448 boost_thread-vc90-mt-1_34_1.dll
10/16/2009 04:23 PM <DIR> com
04/20/2009 08:50 AM 942,592 ExpressionEngine.dll
04/20/2009 08:43 AM 1,036,288 FDO.dll
04/20/2009 08:38 AM 246,272 FDOCommon.dll
04/20/2009 08:38 AM 252,416 FDOGeometry.dll
04/20/2009 08:37 AM 73,216 FDOMessage.dll
10/05/2009 12:10 AM 10,240 FdoRegUtil.exe
04/20/2009 08:39 AM 113,664 FDOSpatial.dll
04/20/2009 08:37 AM 5,091,840 gdal16.dll
10/19/2009 10:40 AM 126,976 geotiff.dll
04/20/2009 09:01 AM 2,560 GRFPMessage.dll
04/20/2009 09:01 AM 72,192 GRFPOverrides.dll
04/20/2009 09:01 AM 274,432 GRFPProvider.dll
10/19/2009 10:40 AM 118,784 jpeg_osgeo.dll
10/19/2009 10:40 AM 458,752 libtiff.dll
04/20/2009 08:57 AM 60,928 ODBCOverrides.dll
04/20/2009 08:59 AM 2,029,056 ODBCProvider.dll
04/20/2009 09:01 AM 152,576 OGRProvider.dll
04/20/2009 08:52 AM 884,224 OWS.dll
10/16/2009 04:24 PM 3,684 providers.xml
04/20/2009 08:54 AM 46,592 RdbmsMsg.dll
04/20/2009 08:57 AM 156,160 RdbmsOverrides.dll
04/20/2009 08:51 AM 13,312 SDFMessage.dll
04/20/2009 08:52 AM 660,992 SDFProvider.dll
04/20/2009 08:49 AM 19,968 SHPMessage.dll
04/20/2009 08:50 AM 47,616 SHPOverrides.dll
04/20/2009 08:51 AM 834,048 SHPProvider.dll
04/20/2009 08:54 AM 39,424 SmMessage.dll
09/25/2009 04:48 PM 752,128 SQLiteProvider.dll
04/20/2009 09:05 AM 129,536 SQLServerSpatialOverrides.dll
04/20/2009 09:06 AM 2,196,480 SQLServerSpatialProvider.dll
04/20/2009 08:52 AM 11,264 WFSMessage.dll
04/20/2009 08:52 AM 451,072 WFSProvider.dll
04/20/2009 08:52 AM 18,944 WMSMessage.dll
04/20/2009 08:52 AM 84,992 WMSOverrides.dll
04/20/2009 08:53 AM 562,176 WMSProvider.dll
04/20/2009 08:29 AM 3,156,480 Xalan-C_1_7_0.dll
04/20/2009 08:24 AM 60,928 XalanMessages_1_7_0.dll
04/20/2009 08:23 AM 2,126,848 xerces-c_2_5_0.dll
10/19/2009 10:40 AM 73,728 zlib_osgeo.dll
41 File(s) 23,473,252 bytes
Directory of X:\Program Files\OSGeo\MapGuide\Server\fdo\com
10/16/2009 04:23 PM <DIR> .
10/16/2009 04:23 PM <DIR> ..
04/20/2009 08:02 AM 6,290 fdosys_sys.sql
04/20/2009 08:02 AM 30,023 fdo_sys.sql
04/20/2009 08:02 AM 7,667 fdo_sys_idx.sql
3 File(s) 43,980 bytes
Total Files Listed:
44 File(s) 23,517,232 bytes
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
