[mapguide-internals] The pinned connection
Traian Stanev traian.stanev at autodesk.com
Tue Oct 20 13:47:02 EDT 2009
It's rather sub-optimal from usability perspective to have to copy a feature source only so that you can pin a connection to it, when it should be possible and not much harder to write code that can pin a number of connections to the same feature source.
Traian
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-
> bounces at lists.osgeo.org] On Behalf Of Badreddine Karoui
> Sent: Tuesday, October 20, 2009 1:41 PM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] The pinned connection
> You mean I cannot create multiple feature source IDs to the same data? That
> sounds like a deployment issue; if an application requires the use of a
> pinned connection and a regular connection at the same time, then I would
> provision 2 feature source ids to the same datastore. Or may be I don't
> understand that part?
> Badreddine
> bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
> Sent: Tuesday, October 20, 2009 1:34 PM
> To: 'MapGuide Internals Mail List'
> ?? Now you are getting me confused :)
> Isn't proposed solution in RFC "PinConnection(MgResourceIdentifier
> featureSourceId)" referring to Feature Source which identifies particular
> Feature Source and it is one unique id for one feature source ?
> Haris
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Badreddine
> Karoui
> Sent: Tuesday, October 20, 2009 19:29
> Why not? I just create 2 FSIDs and pinned them both. An application should
> be able to use any number of unique FSIDs.
> Badreddine
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris
> Kurtagic
> Sent: Tuesday, October 20, 2009 1:24 PM
> Yes, and one of issues of RFC is that you can't have another one
> Haris
> Karoui
> Sent: Tuesday, October 20, 2009 19:11
> I don't think there is anything assumed about what connection is pinned. If
> a PinConnection is called using a specific feature source id, then all the
> calls using that feature source id will use the pinned connection associated
> with that fsid. There is no assumption made, the use of the pinned
> connection is explicit through the use of the feature source id.
> Badreddine
> Kurtagic
> Sent: Tuesday, October 20, 2009 12:57 PM
> Hm, that is not true. Obviously it is a problem otherwise we wouldn't have
> this RFC.
> Connection pooling stays and it is common in web development but have
> nothing to do with this discussion and RFC. Regarding connection pooling
> nothing changes
> I understand what you want to do, I am suggesting to instead of just pin one
> connection and then assume in all other executions that user wanted to use
> that only pinned connection, return that connection ( in a way of new class
> or id or ... ) and then allow connections to be used in commands.
> Haris
> Karoui
> Sent: Tuesday, October 20, 2009 16:28
> In the web environment not having control over which connection to use is
> NOT a problem; It's a feature. The connection pooling/sharing is a
> scalability feature. However, that can be an issue/restriction for some
> special/edge and uncommon cases. For those cases, we have a special solution
> that can be used; temporary pin the connection. BTW. This is similar to
> pinning a .Net managed object when a unmanaged object need to keep a
> reference to the managed object.
> Badreddine
> Kurtagic
> Sent: Tuesday, October 20, 2009 10:11 AM
> Difference is that using feature source id introduce problems we have now
> and which we are trying to solve. And problem is as stated in RFC that
> developer doesn't have control over which database connection is used when
> he wants to execute commands.
> If instead of feature source id, parameter would be connection then we
> wouldn't have this issues and RFC.
> Equivalent changes to API are already suggested in transaction RFC78. So
> changes shouldn't be so difficult.
> Just instead of transaction as suggested in that RFC we could use connection
> as parameter.
> I understand that making such changes will change existing API, I would much
> reader introduce new clear API then changing existing one to support one
> particular case and create existing API more difficult to understand and
> use.
> This is how I believe API should look like:
> Conn1 = Open(FeatureSourceId)
> Execute SQL(Conn1,..)
> Open(Conn2)
> Execute SQL(Conn2,..)
> Open(Conn3)
> Conn3.StartTransaction()
> Conn3.Committ()
> Execute SQL(Conn3,..)
> Close(conn3)
> Close(Conn2)
> Close(Conn1)
> Haris
> Karoui
> Sent: Tuesday, October 20, 2009 15:30
> I'm not sure what is the difference between using the proposed fdo
> connection and using the existing feature source id. It seems that
> introducing the new connection will require more changes to the API since
> all the existing commands use feature source id. If the proposed connection
> will replace the feature source id, then that may not be acceptable since
> that means clients will be pinning all connections. If this is an addition
> to the API where both feature source id and connection will be used, then
> this is cumbersome. I think pinning a connection is an exception/edge case
> that should not be used unless it's absolutely necessary. As a result an
> explicit API as suggested by the RFC is appropriate in this case.
> Badreddine
> Kurtagic
> Sent: Tuesday, October 20, 2009 7:08 AM
> I don't think we confused transaction with what is called pinned connection.
> I think unnecessary confusion and limitations are in application when pinned
> connection is hidden (assumed) to application as it is suggested in RFC.
> My suggestion is that developer can acquire FDO connection and then use that
> connection in ExecuteSql... functions. In that way developer have clear
> picture what is he doing with which FDO connection and can execute any
> combination of operations.
> Reason why I am mentioning RFC78 is because same solution ( but only for
> transactions ) was introduced in the RFC and I think we should combine those
> and make one solution to satisfy all needs.
> Haris
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Leaf Li
> Sent: Tuesday, October 20, 2009 11:46
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] The pinned connection
> It seems we confuse transaction and pinned connection. So before I answer
> you question, l would like to introduce sameness and difference between them
> a little bit.
> Sameness:
> 1. Both transaction and pinned connection will exclusively use one FDO
> connections in FDO connection pool.
> 2. Both transaction and pinned connection will maintain connection state
> information.
> Difference:
> 1. Transaction will guarantee that operations executed in one transaction
> are atomic. So it has commit and rollback method. But it doesn't make sense
> for pinned connection. Pinned connection just guarantee that operations use
> the same FDO connection. Pinned connection doesn't want commit and rollback
> operations.
> 2. One transaction may do something on the DRBMS server when opening a
> transaction. Changes in one transaction isn't visible for operations which
> aren't in the same transaction before committing transaction. It isn't true
> for pinned connection. Changes in one pinned connection can be visible for
> other users. The connection state information that transaction and pinned
> connection maintain is different.
> What we need is a pinned connection. Users can use the same connection when
> calling methods
> ExecuteSqlQuery
> ExecuteSqlNonQuery
> UpdateFeatures
> SelectFeatures
> SelectAggregate
> For example, we can call method ExecuteSqlNonQuery against Oracle feature
> source to execute the following statements,
> LOCK TABLE ...
> ALTER SESSION ...
> CONNECT AS SYSDBA
> Those connection state information should be bound to a users session. For
> example, after one user session execute "CONNECT AS SYSDBA", this FDO
> connection should be bound to this session and can't be used by other users
> session. Otherwise, other users may have SYSDBA access right by using this
> FDO connection.
> This is the motivation of this RFC. It happen we use a nested transaction
> (MapGuide and FDO doesn't support nested transaction) sample and a nested
> data reader sample to show intention. So it may result in some confusing
> between transaction and pinned connection. Hope it is clear now.
> Thanks,
> Leaf Li
> >Hello,
> >My general advice is to avoid extending the API if there is any possible
> >logic which
> >do the job without exposing such internal states to the API.
> >So the question is if there is any business logic to decide this?
> >I think one important thing missing in RFC86 is a complete list of use
> >cases this is wanted for.
> > (Maybe we should focus more on the use cases to be part of any RFC to
> >help further evaluation of it. )
> >The use case/example in RFC86 looks to me like a transaction which
> >should reuse the same FDO connection
> >for the same user session. That was the start of my comment. I believe
> >using a dedicated FDO connection makes
> >a lot of sense for the Transactions.
> >So what are the other use cases?
> >We can easily agree that the FDO connection pool needs to be a little
> >smarter than it is.
> >Exposing those things to the API feels wrong.
> >So can someone help to complete the use cases so we can write the logic
> >to manage the FDO connection pool?
> >In this case we have to consider single user and multi user scenarios.
> >Haris Kurtagic wrote:
> > Leaf, UV,
> > To be able to use only one "pinned" connection in session is unnecessary
> > restriction to application.
> > I think UV comment was correct that this RFC is connected to RFC78 (thanks
> > UV to pointing it out).
> > Instead of adding parameter to set transaction in execute sql functions it
> > should be better to use connection as parameter.
> > On that connection transaction is started or not, which depends of'course
> on
> > application.
> > In such case you can any number of transaction, readers, "pinned"
> > connections whatever.
> > Application is in control how and for what wants to use them. In that case
> > there is no confusion what is pinned what is in transaction etc...
> > Haris
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
