[mapguide-internals] The pinned connection
Badreddine Karoui
badreddine.karoui at autodesk.com
Tue Oct 20 14:10:23 EDT 2009
Again, this is an edge case that should not be used unless it's absolutely necessary. This is needed in conjunction with SQL passthrough and Oracle where the Oracle server may maintain other states/context than transaction state for a given session. In that case the likely use case would be for the application to pin the connection, execute some SQL based operations, unpin the connection and continue with the regular web stateless stuff.
BTW. I always found version 2, Ex, X etc. of existing functions very ugly. I don't think my suggested workaround will be used in this case. But in case an application have a need for such behavior, then it's not locked to the single pinned connection.
Badreddine
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Haris Kurtagic
Sent: Tuesday, October 20, 2009 1:52 PM
To: 'MapGuide Internals Mail List'
Subject: RE: [mapguide-internals] The pinned connection
I wouldn't call it deployment issue. The workaround you suggested is
possible but very ugly.
In my opinion API as it is suggested looks very unnatural, has limitations
and is much different than most of standard APIs.
I can guess that primary reason for such suggested solution in RFC was that
changes in existing API are minimal but it makes API looks really strange.
I would much rather see another set of ExecuteSql (e.g. ExecuteSql2 )
commands then trying to combine old and new in such way.
Haris
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Badreddine
Karoui
Sent: Tuesday, October 20, 2009 19:41
To: MapGuide Internals Mail List
You mean I cannot create multiple feature source IDs to the same data? That
sounds like a deployment issue; if an application requires the use of a
pinned connection and a regular connection at the same time, then I would
provision 2 feature source ids to the same datastore. Or may be I don't
understand that part?
Badreddine
Kurtagic
Sent: Tuesday, October 20, 2009 1:34 PM
?? Now you are getting me confused :)
Isn't proposed solution in RFC "PinConnection(MgResourceIdentifier
featureSourceId)" referring to Feature Source which identifies particular
Feature Source and it is one unique id for one feature source ?
Haris
Karoui
Sent: Tuesday, October 20, 2009 19:29
Why not? I just create 2 FSIDs and pinned them both. An application should
be able to use any number of unique FSIDs.
Badreddine
Kurtagic
Sent: Tuesday, October 20, 2009 1:24 PM
Yes, and one of issues of RFC is that you can't have another one
Haris
Karoui
Sent: Tuesday, October 20, 2009 19:11
I don't think there is anything assumed about what connection is pinned. If
a PinConnection is called using a specific feature source id, then all the
calls using that feature source id will use the pinned connection associated
with that fsid. There is no assumption made, the use of the pinned
connection is explicit through the use of the feature source id.
Badreddine
Kurtagic
Sent: Tuesday, October 20, 2009 12:57 PM
Hm, that is not true. Obviously it is a problem otherwise we wouldn't have
this RFC.
Connection pooling stays and it is common in web development but have
nothing to do with this discussion and RFC. Regarding connection pooling
nothing changes
I understand what you want to do, I am suggesting to instead of just pin one
connection and then assume in all other executions that user wanted to use
that only pinned connection, return that connection ( in a way of new class
or id or ... ) and then allow connections to be used in commands.
Haris
Karoui
Sent: Tuesday, October 20, 2009 16:28
In the web environment not having control over which connection to use is
NOT a problem; It's a feature. The connection pooling/sharing is a
scalability feature. However, that can be an issue/restriction for some
special/edge and uncommon cases. For those cases, we have a special solution
that can be used; temporary pin the connection. BTW. This is similar to
pinning a .Net managed object when a unmanaged object need to keep a
reference to the managed object.
Badreddine
Kurtagic
Sent: Tuesday, October 20, 2009 10:11 AM
Difference is that using feature source id introduce problems we have now
and which we are trying to solve. And problem is as stated in RFC that
developer doesn't have control over which database connection is used when
he wants to execute commands.
If instead of feature source id, parameter would be connection then we
wouldn't have this issues and RFC.
Equivalent changes to API are already suggested in transaction RFC78. So
changes shouldn't be so difficult.
Just instead of transaction as suggested in that RFC we could use connection
as parameter.
I understand that making such changes will change existing API, I would much
reader introduce new clear API then changing existing one to support one
particular case and create existing API more difficult to understand and
use.
This is how I believe API should look like:
Conn1 = Open(FeatureSourceId)
Execute SQL(Conn1,..)
Open(Conn2)
Execute SQL(Conn2,..)
Open(Conn3)
Conn3.StartTransaction()
Conn3.Committ()
Execute SQL(Conn3,..)
Close(conn3)
Close(Conn2)
Close(Conn1)
Haris
Karoui
Sent: Tuesday, October 20, 2009 15:30
I'm not sure what is the difference between using the proposed fdo
connection and using the existing feature source id. It seems that
introducing the new connection will require more changes to the API since
all the existing commands use feature source id. If the proposed connection
will replace the feature source id, then that may not be acceptable since
that means clients will be pinning all connections. If this is an addition
to the API where both feature source id and connection will be used, then
this is cumbersome. I think pinning a connection is an exception/edge case
that should not be used unless it's absolutely necessary. As a result an
explicit API as suggested by the RFC is appropriate in this case.
Badreddine
Kurtagic
Sent: Tuesday, October 20, 2009 7:08 AM
I don't think we confused transaction with what is called pinned connection.
I think unnecessary confusion and limitations are in application when pinned
connection is hidden (assumed) to application as it is suggested in RFC.
My suggestion is that developer can acquire FDO connection and then use that
connection in ExecuteSql... functions. In that way developer have clear
picture what is he doing with which FDO connection and can execute any
combination of operations.
Reason why I am mentioning RFC78 is because same solution ( but only for
transactions ) was introduced in the RFC and I think we should combine those
and make one solution to satisfy all needs.
Haris
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Leaf Li
Sent: Tuesday, October 20, 2009 11:46
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] The pinned connection
It seems we confuse transaction and pinned connection. So before I answer
you question, l would like to introduce sameness and difference between them
a little bit.
Sameness:
1. Both transaction and pinned connection will exclusively use one FDO
connections in FDO connection pool.
2. Both transaction and pinned connection will maintain connection state
information.
Difference:
1. Transaction will guarantee that operations executed in one transaction
are atomic. So it has commit and rollback method. But it doesn't make sense
for pinned connection. Pinned connection just guarantee that operations use
the same FDO connection. Pinned connection doesn't want commit and rollback
operations.
2. One transaction may do something on the DRBMS server when opening a
transaction. Changes in one transaction isn't visible for operations which
aren't in the same transaction before committing transaction. It isn't true
for pinned connection. Changes in one pinned connection can be visible for
other users. The connection state information that transaction and pinned
connection maintain is different.
What we need is a pinned connection. Users can use the same connection when
calling methods
ExecuteSqlQuery
ExecuteSqlNonQuery
UpdateFeatures
SelectFeatures
SelectAggregate
For example, we can call method ExecuteSqlNonQuery against Oracle feature
source to execute the following statements,
LOCK TABLE ...
ALTER SESSION ...
CONNECT AS SYSDBA
Those connection state information should be bound to a users session. For
example, after one user session execute "CONNECT AS SYSDBA", this FDO
connection should be bound to this session and can't be used by other users
session. Otherwise, other users may have SYSDBA access right by using this
FDO connection.
This is the motivation of this RFC. It happen we use a nested transaction
(MapGuide and FDO doesn't support nested transaction) sample and a nested
data reader sample to show intention. So it may result in some confusing
between transaction and pinned connection. Hope it is clear now.
Thanks,
Leaf Li
>Hello,
>My general advice is to avoid extending the API if there is any possible
>logic which
>do the job without exposing such internal states to the API.
>So the question is if there is any business logic to decide this?
>I think one important thing missing in RFC86 is a complete list of use
>cases this is wanted for.
> (Maybe we should focus more on the use cases to be part of any RFC to
>help further evaluation of it. )
>The use case/example in RFC86 looks to me like a transaction which
>should reuse the same FDO connection
>for the same user session. That was the start of my comment. I believe
>using a dedicated FDO connection makes
>a lot of sense for the Transactions.
>So what are the other use cases?
>We can easily agree that the FDO connection pool needs to be a little
>smarter than it is.
>Exposing those things to the API feels wrong.
>So can someone help to complete the use cases so we can write the logic
>to manage the FDO connection pool?
>In this case we have to consider single user and multi user scenarios.
>Haris Kurtagic wrote:
> Leaf, UV,
> To be able to use only one "pinned" connection in session is unnecessary
> restriction to application.
> I think UV comment was correct that this RFC is connected to RFC78 (thanks
> UV to pointing it out).
> Instead of adding parameter to set transaction in execute sql functions it
> should be better to use connection as parameter.
> On that connection transaction is started or not, which depends of'course
on
> application.
> In such case you can any number of transaction, readers, "pinned"
> connections whatever.
> Application is in control how and for what wants to use them. In that case
> there is no confusion what is pinned what is in transaction etc...
> Haris
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
