[mapguide-internals] RFC60 finalization
Jason Birch jason at jasonbirch.com
Fri Oct 23 12:37:05 EDT 2009
Oh, sorry, I got confused between UV's initial reference to FDO
lookups, and Walts objection about the external symbol definition
lookups.  Must pay more attention to actual words...
On 2009-10-23, Tom Fukushima <tom.fukushima at autodesk.com> wrote:
> I'm trying to understand this...so correct me if I'm wrong.  But it seems
> that the problem is not with attribute-based stylization.  It's that if
> someone uses referenced symbols (that is, the LayerDefinition specifies a
> resource using a resource ID such as Library://mysymbols/a.SymbolDefinition
> instead of embedded XML for a SymbolDefinition in the LayerDefinition) then
> a large part of the code will need to be rewritten to support it.
> If the above is the case, I understand that we need to make tradeoffs all
> the time, and this may be where we need to make one.  I think though that it
> would be advantageous for the current developer to do the requested
> refactoring now while it is fresh.  Later, if defects are found or
> refinements (e.g., attribute-based stylization) are done, they could be
> addressed at that time---and this would be manageable because wouldn't
> require refactoring large parts of the code.
> Could we get some idea of the work that would be required to get support for
> the referenced symbol definitions?
> Note that I'm not saying it has to be done (but of course I would prefer it
> to be done), I'm trying to get more information on this sticking point (I
> believe it is the only one right?) to try to make a judgment.
> Tom
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Friday, October 23, 2009 9:24 AM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] RFC60 finalization
> It seems to me that we have frequently (too often perhaps?) favoured
> expediency over correctness when faced with resourcing or timeline
> issues.
> In this case, I'm in favour of placing the burden of change on the
> whoever deems that it is critical to support pallette reservation for
> Jason
> On 2009-10-23, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
>>> Secondly, it think it is wrong to request the implementation of the new
>>> stylization for such transparent feature addition.
>>> RFC60 works fine for our case, why should we implement something that
>>> does not harm anything but what we do not need?
>> The way your code is designed - where it does the work of grabbing the
>> colors inside the MdfModel project - WILL NOT WORK for enhanced
>> stylization
>> in which there are referenced symbol definitions.  It's not possible to
>> load
>> referenced symbols from the resource service from inside the MdfModel
>> code.
>> This is not a minor defect.  It requires that a lot of your code be
>> refactored.  I already explained the problem last March.  Here's the
>> excerpt:
>> "With the new enhanced stylization (RFC 14) the layer definition can
>> reference symbol definitions (in addition to inlining them).  The symbols,
>> of course, define colors which need to be accounted for.  Accessing
>> referenced symbol definitions requires the resource service - we need to
>> get
>> the symbol definition resource from the service.  The MdfModel project
>> (where VectorLayerDefinition is stored) does not have access (nor want
>> access) to the resource service.  So if you want to properly support the
>> new
>> enhanced stylization with your RFC (you should) then we'll probably have
>> to
>> move this ComputeUsedColors method somewhere else.  There's a method -
>> MgMappingUtil::ComputeStylizationOffset - which does something analogous
>> to
>> ComputeUsedColors, so possibly we can add ComputeUsedColors to
>> MgMappingUtil."
>> So even if you don't add code to actually parse colors for enhanced style
>> layers, you need to keep the bigger picture in mind and design your new
>> code
>> so it will be easy to add this support.
>> All along that's the real reason why I wanted you to take a look at this.
>> So that you would come to realize that your current design doesn't fully
>> work as is.
>>> Open source is more like: Who needs it should code it!
>> True, but it's not an excuse for not doing the right thing.  People can't
>> just add anything they want without taking account the bigger picture.
>> That's my take on this.
>> Walt
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
>> Sent: Friday, October 23, 2009 9:03 AM
>> Subject: [mapguide-internals] RFC60 finalization
>> Hi all,
>> I looked into the RFC60 code again and added some more features to it
>> e.g. finding label colors.
>> However, a redirection of referenced featureIds which would cause a FDO
>> lookup seems prohibitive expensive in this context.
>> I would not like to add this into the code simply as it could increase
>> delay tile computation a lot.
>> So the interesting test here are performance related. Simple unit-tests
>> are not sufficient for this.
>> Creating complex test data to test performance issues is tedious and
>> very badly motivated!!! (specification vs. implementation from same hand)
>> This is not thought along open source paradigms.  Open source is more
>> So we should leave this open and the next person that has real test data
>> which doesn't work can post a defect!
>> Very easy process!
>> RFC60 is not trivial at all but it solves a real problem in real maps.
>> To block the inclusion of RFC60 into the code base on those matters is
>> simply wrong in open source terms as it keeps others from using a new
>> working feature.
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
