[mapguide-internals] RE: The pinned connection
Leaf Li
leaf.li at autodesk.com
Fri Oct 23 20:39:47 EDT 2009
Hi Haris,
If my understanding is correct, you propose two solutions in our discussion. One is simpler. This solution will not affect MgTransaction.
MgPinnedConnection conn = nullptr;
try
conn = MgFeatureService.GetPinnedConnection(resourceId);
MgFeatureService.ExecuteSql(resourceId, sql statement1, conn);
MgFeatureService.ExecuteSql(resourceId, sql statement2, conn);
MgFeatureService.UpdateFeatures(resourceId, MgFeatureCommandCollection, conn);
conn.Release();
catch (NoPinnedConnectionAvailableException ex)
Another is in this way. It affects MgTransaction. So we have to change current design of MapGuide RFC 78 - Enhance transaction capability to Feature Service. For example, transaction isn’t started, committed and rollbacked by MgFeautreService. It is done by MgPinnedConnection.
> Conn1 = Open(FeatureSourceId)
> Execute SQL(Conn1,..)
> Open(Conn2)
> Execute SQL(Conn2,..)
> Open(Conn3)
> Conn3.StartTransaction()
> Conn3.Committ()
> Execute SQL(Conn3,..)
> Close(conn3)
> Close(Conn2)
> Close(Conn1)
For the second, it think it is the perfect way. I think you are talking about the first solution in the email below. There are some issues for the first solution. One of issues is how to execute a transaction against a existing pinned connection? Maybe we need to add the following method. Right?
ExecuteSqlNonQuery(MgResourceIdentifier, string, MgTransaction, MgPinnedConnection)
However, MgTransaction already occupies a connection when calling FeatureService::BeginTransaction(…). How do we handle them in this time?
So if we want to return a MgPinnedConnection object to users, we should use the second solution to start a transaction instead of FeatureService::BeginTransaction(…).
Thanks,
Leaf Li
>Hi Li,
>I think that more work is needed for API as proposed in RFC because there is
>functionality around pinning and unpinning connections and keeping track of
>those. All functionality for the solution I would prefer is already there,
>it is just about the way how is it exposed.
>It does changes API but in same way as it changes with transaction RFC78.
>My suggestion would be just to change that one and instead of adding
>transaction as new parameter add connection. And then on connection just use
>transaction functionality which was developed for RFC78.
Haris
More information about the mapguide-internals
