[mapguide-internals] Server status/Ping API
Bruce Dechant bruce.dechant at autodesk.com
Mon Oct 26 14:07:28 EDT 2009
I think it should be optional regardless :)
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, October 26, 2009 10:44 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Server status/Ping API
Works for me. Good suggestion Walt. If it's that quick to render do we need to make it optional?
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
Sent: Monday, October 26, 2009 10:28 AM
Works for me...
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt Welton-Lair
Sent: Monday, October 26, 2009 12:25 PM
How about reducing this to just a legend image?  That will still exercise rendering, but it avoids the overhead of making FDO calls.
Sent: Monday, October 26, 2009 12:09 PM
If we assume the image is a test image only then I wouldn't be concerned about the map and credentials. We could even supply a default one that is a variation of Sheboygan or something with 1 or 2 layers max. Since the eventual request is server side it could use the server authentication to access and render the map.
I'm more concerned about how you get multiple results back from all sites. I'm guessing the request is a multipart post that processes each server one by one in a loop in the webtier or does it process them all, assemble the results (including any failures) and return one result set?
Dave
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
Sent: Monday, October 26, 2009 9:23 AM
A ping is supposed to be fast - adding overhead to generate a map image could be slow, but having this optional would get around that. What about security risks of being able to render a map without credentials? Obviously if it is a tiny thumbnail of the map it is not very useful at all - other than to see if the server is there and can render it.
Thanks,
Bruce
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Monday, October 26, 2009 8:08 AM
No problem on the performance metrics.
Martin's suggestion of doing a lightweight render is a good idea.  Perhaps we can make this an optional item with the render only occurring if a map definition resource id is supplied as an input parameter.  We could just render a small image at the map extents.  The various pieces - API version, offline/online, and image could be returned as an xml document with the image returned as a base64 blob.  Something like this perhaps:
<Ping>
  <Status>Online</Status>
  <ApiVersion>2.2</ApiVersion>
  <ImageSize>8061</ImageSize>
  <Image>[8061 base64 encoded bytes]</Image>
</Ping>
Thanks,
Trevor
Sent: October 26, 2009 7:55 AM
The API version would be nice to have.
I have to agree that performance metrics without credentials I'm not sure I like.
Bruce
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Sunday, October 25, 2009 11:00 AM
Subject: Re: [mapguide-internals] Server status/Ping API
I think it would be cool to return API version (2.1, 2.2, etc) as part
of this, but not rev/build.
Would be hesitant to return performance metrics through a non-authenticated api.
Jason
On 2009-10-22, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
> Hi All,
> The existing Server Admin service has the following APIs that are not
> officially published but are available to use:
> GetSiteVersion() - returns the exact MapGuide server version
> GetSiteInfo() - returns MapGuide server information and OS information
> Both of these require authentication credentials because of the information
> returned.
> I was wondering about adding a new API that would not require authentication
> credentials.
> Example: GetSiteStatus()
> I would like it to return the server status as either "Offline" or "Online"
> as some of the information.
> This API could be used as a sort of "ping" if needed.
> What other non sensitive information do you think we could include with this
> API?
> Thanks,
> Bruce
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
