[mapguide-internals] Server status/Ping API
Martin Morrison martin.morrison at edsi.com
Mon Oct 26 17:03:57 EDT 2009
So let the image have an arg for an FDO connection.  If the arg is present, read the FDO, if not use the legend image.
Being able to monitor Mapguide/Apache with SNMP would be the cat's meow...is it doable with the resources we have?
Martin
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Monday, October 26, 2009 4:57 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Server status/Ping API
my experience is the same as Jason, FDO is usually the problem ( hence
my orginal concerns about the pinned connections, but thats a different thread)
can i throw SNMP into the mix here? rather than re-inventing the wheel,
supporting SNMP would allow straight forward integration into
existing monitoring systems...
On Tue, Oct 27, 2009 at 7:17 AM, Jason Birch <jason at jasonbirch.com> wrote:
> In my experience, if a map isn't rendering it's often the FDO (connections)
> layer that's hung.
> 2009/10/26 Walt Welton-Lair <walt.welton-lair at autodesk.com>
>> How about reducing this to just a legend image?  That will still exercise
>> rendering, but it avoids the overhead of making FDO calls.
>> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
>> Sent: Monday, October 26, 2009 12:09 PM
>> Subject: RE: [mapguide-internals] Server status/Ping API
>> If we assume the image is a test image only then I wouldn't be concerned
>> about the map and credentials. We could even supply a default one that is a
>> variation of Sheboygan or something with 1 or 2 layers max. Since the
>> eventual request is server side it could use the server authentication to
>> access and render the map.
>> I'm more concerned about how you get multiple results back from all sites.
>> I'm guessing the request is a multipart post that processes each server one
>> by one in a loop in the webtier or does it process them all, assemble the
>> results (including any failures) and return one result set?
>> Dave
>> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Bruce Dechant
>> Sent: Monday, October 26, 2009 9:23 AM
>> A ping is supposed to be fast - adding overhead to generate a map image
>> could be slow, but having this optional would get around that. What about
>> security risks of being able to render a map without credentials? Obviously
>> if it is a tiny thumbnail of the map it is not very useful at all - other
>> than to see if the server is there and can render it.
>> Thanks,
>> Bruce
>> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
>> Sent: Monday, October 26, 2009 8:08 AM
>> No problem on the performance metrics.
>> Martin's suggestion of doing a lightweight render is a good idea.  Perhaps
>> we can make this an optional item with the render only occurring if a map
>> definition resource id is supplied as an input parameter.  We could just
>> render a small image at the map extents.  The various pieces - API version,
>> offline/online, and image could be returned as an xml document with the
>> image returned as a base64 blob.  Something like this perhaps:
>> <Ping>
>>  <Status>Online</Status>
>>  <ApiVersion>2.2</ApiVersion>
>>  <ImageSize>8061</ImageSize>
>>  <Image>[8061 base64 encoded bytes]</Image>
>> </Ping>
>> Thanks,
>> Trevor
>> Sent: October 26, 2009 7:55 AM
>> The API version would be nice to have.
>> I have to agree that performance metrics without credentials I'm not sure I
>> like.
>> Bruce
>> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
>> Sent: Sunday, October 25, 2009 11:00 AM
>> I think it would be cool to return API version (2.1, 2.2, etc) as part
>> of this, but not rev/build.
>> Would be hesitant to return performance metrics through a non-authenticated
>> api.
>> Jason
>> On 2009-10-22, Bruce Dechant <bruce.dechant at autodesk.com> wrote:
>> > Hi All,
>> > The existing Server Admin service has the following APIs that are not
>> > officially published but are available to use:
>> > GetSiteVersion() - returns the exact MapGuide server version
>> > GetSiteInfo() - returns MapGuide server information and OS information
>> > Both of these require authentication credentials because of the
>> information
>> > returned.
>> > I was wondering about adding a new API that would not require
>> authentication
>> > credentials.
>> > Example: GetSiteStatus()
>> > I would like it to return the server status as either "Offline" or
>> "Online"
>> > as some of the information.
>> > This API could be used as a sort of "ping" if needed.
>> > What other non sensitive information do you think we could include with
>> this
>> > API?
>> > Thanks,
>> > Bruce
>> > _______________________________________________
>> > mapguide-internals mailing list
>> > mapguide-internals at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
