[mapguide-internals] RE: mapguide-internals Digest, Vol 33, Issue 15
Leaf Li leaf.li at autodesk.com
Sun Sep 20 23:30:35 EDT 2009
Hi Trevor,
Yes. Fetch size is 0 by default. I add it in RFC.
As for ExecuteSqlQuery, a new signature with fetchSize is already added in RFC. However, we just need add one new signature instead of two because method 1 is an extension to method 2. And method 3 is an extension is to method 3. Method 3 includes all functionality of method 1 and 2.
1. virtual MgSqlDataReader* ExecuteSqlQuery(
                                 MgResourceIdentifier* resource,
                                 CREFSTRING sqlStatement);
2. virtual MgSqlDataReader* ExecuteSqlQuery(
                                 CREFSTRING sqlStatement,
                                 MgParameterCollection* params,
                                 MgTransaction* transaction);
3. virtual MgSqlDataReader* ExecuteSqlQuery(
                                 MgTransaction* transaction,
                                 INT32 fetchSize);
Thanks,
Leaf Li
Message: 3
Date: Wed, 16 Sep 2009 07:02:55 -0700
From: Trevor Wekel <trevor_wekel at otxsystems.com>
Subject: [mapguide-internals] RE: MapGuide RFC 84 is updated.
To: MapGuide Internals Mail List <mapguide-internals at lists.osgeo.org>
Message-ID:
	<7661E3F3A90DBC47869E52672C2E4159F339A0CFD5 at VA3DIAXVS121.RED001.local>
Content-Type: text/plain; charset="iso-8859-1"
Hi Leaf,  updating MgFeatureQueryOptions instead of the SelectFeatures, SelectAggregate signatures makes sense to me.  The internal member variable should default to 0 to retain the current behaviour of the existing API methods.
Since ExecuteSqlQuery does not use MgFeatureQueryOptions, a new signature with the fetchSize parameter will have to be added.  Both signatures for ExecuteSqlQuery will have to remain in the API for backward compatibility.
Thanks,
Trevor
More information about the mapguide-internals mailing list
