Fusion versioning (was Re: [mapguide-internals] RE: Recent submissions by UV)
Trevor Wekel trevor_wekel at otxsystems.com
Tue Sep 22 13:21:29 EDT 2009
Hi Paul,
The only reason I was considering only using 1887 in the branch is that it had already been released to the community.  However, there is a bit of an underlying issue with grabbing Fusion trunk - scope creep.  As far as I know, the following 2.2 RFCs do impact Fusion:
RFC 66 Prevent session timeout, and give better error messages
RFC 72 Commercial Map Service Support
It looks as though the RFC 72 work started in April so it is unrealistic to pull these features from (soon to be) Fusion 2.0.  It just means that the community may have to do more testing if they are using Fusion.  Using 1887 versus tip will not change this so we might as well just use the tip of trunk for Fusion 2.0.
On the plus side, we will effectively get some 2.2 Fusion testing out of the community from the 2.1 release.  That's not a bad thing.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul Spencer
Sent: September 22, 2009 10:34 AM
To: MapGuide Internals Mail List
Subject: Fusion versioning (was Re: [mapguide-internals] RE: Recent submissions by UV)
Mike is looking at the P1 bugs in trac right now and fixing what he
can today, then we will svn del the fusion 2.0 branch and svn copy
trunk to fusion 2.0 branch (the wholesale change) at the end of the
day.  This will form the basis of a fusion 2.0 beta 1 release, but I
think there are a few more bugs that should be looked at before we
actually release a beta (of fusion).
Most of the changes between 1887 and 1903 (the latest one) are related
to fixing autodesk-reported defects which I am sure they will want in
the branch.  Is there any particular reason why you don't want to
include changes after 1887?
We will go through the Fusion issue list and try to rejig things into
the right milestones and priorities as soon as we can log into trace.
It will also help if we can get some feedback on which are the highest
priority issues from the mapguide community/developers.
Things that jump out to me are the Measure widget, making sure
anonymous access works properly, commercial layer issues, and some
Legend related issues.  Probably any enhancements will be deferred
until after 2.0
Paul
On 2009-09-22, at 11:44 AM, Trevor Wekel wrote:
> The last MapGuide build Jason posted to http://download.osgeo.org/mapguide/testing/
>  was on August 3rd.  I did a quick scan on the Fusion trunk code
> base and compared it to the Fusion tree installed by the build.  It
> looks as though http://trac.osgeo.org/fusion/changeset/1887 dated
> July 28th was the last change present in the August 3rd posting.
> Jason has done some testing on the build and the community has had
> access to the build with Fusion trunk for a month and a half.
> Instead of trying to backport a set of fixes to Fusion 2.0, Jason
> has suggested we simply do a wholesale replace of Fusion 2.0 from
> Fusion trunk.  I agree with his approach as long as we use changeset
> 1887 for Fusion 2.0.
> And a wholesale replace is much easier than backporting...
> Thanks,
> Trevor
> internals-bounces at lists.osgeo.org] On Behalf Of Mike Adair
> Sent: September 22, 2009 7:47 AM
> Subject: Re: [mapguide-internals] RE: Recent submissions by UV
> It would be helpful to know which bugs are critical to be fixed for
> the
> release.  There is a long list there now and I don't see them all
> getting fixed soon so if we can get the most important ones marked as
> P1, we can tackle those first.
> Mike
> Paul Spencer wrote:
>> I'll talk to Mike about taking the current trunk version of fusion
>> over to the 2.0 branch and starting with a 2.0 beta 1 release.
>> Hopefully this will happen tomorrow.
>> Cheers
>> Paul
>> On 2009-09-21, at 4:49 PM, Trevor Wekel wrote:
>>> Hi Jason,
>>> Since the latest test build contained Fusion trunk, we could say
>>> that
>>> it has already been released to the community.  We are bending the
>>> rules a bit but I am ok with calling it RC1.  Since RFC 60 needs
>>> official review, I think we should defer it to MGOS 2.2.
>>> Will this work for an MGOS 2.1 timeline given that the MGOS code
>>> base
>>> has already been released and service packed "elsewhere"?
>>> - This week MGOS 2.1 RC1
>>> - Week of October 19th MGOS 2.1 Final Release.  Note: The RC1 build
>>> may simply be promoted to Final Release if no showstopper defects
>>> are
>>> found.
>>> I would also like to start producing MGOS 2.2 Beta builds ASAP.  I
>>> think it would be good to target October 9th as the date for the
>>> first MGOS 2.2 Beta.
>>> I should have RFC 60 reverted in an hour or so.
>>> Thanks,
>>> Trevor
>>> Jason Birch
>>> Sent: September 21, 2009 2:13 PM
>>> Although I was of the same thought initially, I don' think we can
>>> count on a
>>> Fusion release.  My current thought is to release a 2.1 RC with
>>> Fusion
>>> trunk.  I hope to be able to get this built today.
>>> Jason
>>> 2009/9/21 Andy Morsell <amorsell at spatialgis.com>
>>>> Regarding the release decision: before we make a decision I think
>>>> that we
>>>> need a date estimate on the Fusion update.  I am in the "release
>>>> only when
>>>> Fusion is updated" camp, but I also agree that if we wait much
>>>> longer then
>>>> we are going to have a mutiny on our hands.  Also, if RFC 60 is not
>>>> included, what exactly is the impact on the general user community?
>>>> Andy
>>>> From: Trevor Wekel [mailto:trevor_wekel at otxsystems.com]
>>>> Sent: Monday, September 21, 2009 9:48 AM
>>>> Subject: [mapguide-internals] RE: Recent submissions by UV
>>>> UV's commit rights were granted under the assumption that he would
>>>> commit
>>>> only to the sandbox.  Personally I am disappointed in what has
>>>> happened
>>>> whether it was accidental or otherwise.  I  can perform the cleanup
>>>> work if
>>>> that is what we want to do.
>>>> I think we need to make the call ASAP as to what is going into the
>>>> release.
>>>> Some members of the community are telling us to ship it now, some
>>>> would
>>>> like
>>>> to see RFC 60 implemented, and some would like a Fusion update.
>>>> Thanks,
>>>> Trevor
>>>> Tom
>>>> Fukushima
>>>> Sent: September 21, 2009 9:49 AM
>>>> In order to reduce the amount of work that might be required to
>>>> clean this
>>>> up, I have removed UV's commit rights for now, but will add them
>>>> again once
>>>> we get this cleared up.
>>>> Bruce
>>>> Dechant
>>>> Sent: Monday, September 21, 2009 9:41 AM
>>>> Subject: [mapguide-internals] Recent submissions by UV
>>>> Hi All,
>>>> I thought UV was only supposed to make submissions to his RFC60
>>>> sandbox
>>>> that
>>>> was just created.
>>>> He has just made several submissions to branch/2.1 and not
>>>> sandbox -
>>>> some
>>>> of
>>>> the submissions are RFC60 related and others are not.
>>>> Have these submissions been code reviewed? I don't see a trac
>>>> ticket
>>>> for
>>>> any
>>>> of the submissions.
>>>> Thanks,
>>>> Bruce
>>>> _______________________________________________
>>>> mapguide-internals mailing list
>>>> mapguide-internals at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>>   Paul Spencer
>>   Chief Technology Officer
>>   DM Solutions Group Inc
>>   http://research.dmsolutions.ca/
>   Michael Adair
>   Senior Software Architect
>   DM Solutions Group Inc.
>   Office: (613) 565-5056 x26
>   madair at dmsolutions.ca
>   http://www.dmsolutions.ca
    Paul Spencer
More information about the mapguide-internals mailing list
