[mapguide-internals] Toggling layers on and off in a load tester
application.
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Sep 25 13:30:17 EDT 2009
I just saw that you are using C# somewhere.
If possible, you can use the MaestroAPI to
toggle layers via. http.
It requires binary
access, so it will be hard to port to clean JS.
Regards, Kenneth Skovhede, GEOGRAF A/S
Kenneth Skovhede, GEOGRAF A/S skrev:
> AFAIK, it is not possible to toggle layers on/off from
> a client request, even if the GUID items are present.
> I have never gotten it to work, and can't see it being done
> in the viewer either.
> You need a server side script to toggle the layer visibility
> in the runtime map.
> I wrote RFC 21 way back, which would support something like this:
> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc21
> I would LOVE to have every API function supported
> in the http interface, so more functions can be performed
> without having server side access.
> The RFC should probably be scrapped, and a new one written
> that states that all API methods should have a http equivalent.
> I'm guessing that the REST API that Jason & Harris put up,
> can support something like this, but it's still a server item
> that needs to be installed.
> Carl Jokl skrev:
>> I am fairly far along in in development of a .Net MapGuide Enterprise
>> load
>> tester. I have recently had some problems when trying to toggle
>> layers on
>> and off on the test map. I thought that this was working but it looks
>> like
>> it may not have been after all.
>> I used the grider script as a starting point and ported the
>> functionality to
>> .Net using our own MapGuide framework's HttpRequest making component.
>> The problem which I am having is that when I am calling the code to
>> turn off
>> a layer and getting the image back the image does not show that layer
>> having
>> been turned off. I even used FireFox live headers to observer every
>> request
>> which the AJAX viewer makes to the server and my code is making
>> requests in
>> identical format and yet for me it isn't working. I have
>> functionality to
>> translate layer names to ids as I know layer object ids need to be
>> submitted. I have tried both the route of creating an overlay image
>> as well
>> as just creating a regular map image. Neither approach is showing the
>> layer
>> I am trying to hide being hidden. I can't see what is different about
>> the
>> requests that I am making from those made by the Ajax Viewer. I feel
>> like I
>> have tried just about everything at this point. Matching even the
>> parameter
>> order (not that this should matter in Http but you never know when
>> dealing
>> with Autodesk Software). We are using MapGuide Enterprise 2010
>> Service Pack
>> 1. There is the BEHAVIOR parameter. I am using the same one as the AJAX
>> viewer but I don't know what behaviour is associated with each
>> number. I am
>> not sure if this is even documented as I might guess a lot of this
>> stress
>> testing work is based on a fair amount of reverse engineering.
>> I did notice for a lot of the requests to create a dynamic map image
>> overlay
>> by the AJAX view the CLIENTAGENT parameter appears twice in the url
>> query. I
>> am pretty sure that this is a viewer bug.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
