[fdo-internals] RE: [mapguide-internals] fdo installation & build script confusion
Trevor Wekel trevor_wekel at otxsystems.com
Fri Sep 25 19:13:57 EDT 2009
Tom,
So official build infrastructure and a transparent way to perform code reviews on community submissions is not in the project's best interest?
Yes.  Hosting, licensing, etc. fees will cost me $500/month or more when I move to colocation.  At this point in time, I have not asked the project to fund any of this.  Obviously, I would be pleased if they did.  But it is up to the PSC to decide what happens with sponsorship funding if/when we receive it.
And frankly, I think $500/month to host 4 machines on a private firewalled VLAN using redundant hardware with automated backup is very competitive.
Sincerely,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
Sent: September 25, 2009 11:41 AM
To: MapGuide Internals Mail List
Subject: RE: [fdo-internals] RE: [mapguide-internals] fdo installation & build script confusion
I saw that you gave a pretty steep price tag to keep a system like this running (was it $500/month?).  I don't think that something like this would be in the project's best interest.
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
Sent: Friday, September 25, 2009 11:28 AM
Hi everyone,
I can start looking into code review infrastructure once we've got the builds sorted out.  The build infrastructure will be moving to a colocation site in a couple of weeks.  This will provide sufficient bandwidth and availability to host a code review tool.
Autodesk uses Smart Bear's Code Collaborator http://smartbear.com/codecollab.php.  According to their website, the tool is free for Open Source projects.  I can set it up in a few weeks so we can try it out.  If we don't like it, we can just turf it.
Thanks,
Trevor
Sent: September 25, 2009 10:16 AM
The process for patches is described on our main trac page: http://trac.osgeo.org/mapguide/. Please continue to follow that for now.
The problem with doing patch reviews using other methods is that there is no public history of the review and so the PSC may not have the information required when considering moving someone from a "Project Contributor" to a "Project Developer".
From: fdo-internals-bounces at lists.osgeo.org [mailto:fdo-internals-bounces at lists.osgeo.org] On Behalf Of UV
Sent: Thursday, September 24, 2009 8:50 PM
To: FDO Internals Mail List
Cc: MapGuide Internals Mail List
Subject: Re: [fdo-internals] RE: [mapguide-internals] fdo installation & build script confusion
Fair enough!
I think also mapguide debug with fdo release might be a popular
combination....
Looks like it makes more sense that the install script of the fdo
package is updated....
however i had to change the paths in my installations manually a few
times already.
for the build server fixing it in the scripts will be mandatory.
just too bad that  in the current devel process i am writing a  lot more
messages than the code that needs only little tweaks...
I suggest to consider a synchronuous peer review process where small
patches can be instantly accepted in a brief
chat or skype session after at least 3 people looked at it.
Tom Fukushima wrote:
> Let's see if I understand this...Does this work if I need to do both a 32-bit and 64-bit build using the a single version of the source?  This is what the build machine will need to do.  If the answer is no then I think that the change should be made in the FDO build scripts to put the binaries into the correct bin subfolder {bin\release, bin\release64, bin\debug, bin\debug64}.
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of UV
> Sent: Wednesday, September 23, 2009 6:17 PM
> To: MapGuide Internals Mail List; FDO Internals Mail List
> Subject: [mapguide-internals] fdo installation & build script confusion
> In order to test my sandbox branched from trunk I needed to compile FDO
> from trunk as there are no build server is creating HEAD builds for this
> yet.
> this cannot work out of the box because of path issues.
> the mapguide buildscript checks for
> MgDev\Oem\FDO\Bin\%TYPEBUILD%
> whereas the FDO build.bat installs into
> MgDev\Oem\FDO\Bin
> MgDev\Oem\FDO\Inc
> MgDev\Oem\FDO\Lib
> I included a patch for mapguide MgDev\build.bat to make this work more
> intuitively as those build scripts still are a lot easier to use  than
> many separate VS solutions
> now you can build FDO & mapguide
> using:
>  >cd %PATH_TO_FDO%
>  >build -a=buildinstall -o=%PATH_TO_MGDEV%\Oem
>  >cd %PATH_TO_MGDEV%
>  >build
> I know this is between to separate OsGeo projects but not being
> responsible does not make it go away.
> fdo-internals mailing list
> fdo-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-internals
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
