[mapguide-internals] RE: Documenting
Zac Spitzer zac.spitzer at gmail.com
Wed Apr 7 19:20:51 EDT 2010
Can we consider introducing error codes which make diagnosing problems
a lot easier than searching for fairly generic error messages?
It makes working with Oracle very easy to research and solve problems
z
On 7 April 2010 22:04, Martin Morrison <martin.morrison at edsi.com> wrote:
> It was disorganized and inaccurate enough I didn't bother trying to continue.  There was a big disconnect between what I was reading on the list about building/compiling vs the documentation.
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Tom Fukushima
> Sent: Tuesday, April 06, 2010 7:19 PM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] RE: Documenting
> Thanks for your input Martin and Walt.  As Jason says there is some documentation for this already but when I look for it, it seems disorganized and out of date.  Other than that do you have see any other problems with the existing documentation on building and configuring?  If not I will see if we can put some time into organizing it and making it up to date!
> Thanks
> Tom
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt Welton-Lair
> Sent: Monday, April 05, 2010 11:30 AM
> I agree with Martin.
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Martin Morrison
> Sent: Monday, April 05, 2010 1:15 PM
> Building.  You have to build it before you can configure it...
> Configure. You have to configure it before you can debug it...
> I'm partial to Windows/Apache, but both should be done...Windows first <G>.
> Sent: Monday, April 05, 2010 1:11 PM
> (Resending with hopefully better formatting than last time)
> Hi Developers,
> We have some money that we would like to put toward documentation (http://producingoss.com/en/producingoss.html#documentation) in order to make the barrier for new developers lower; if you could only pick one or two from the following which would you pick?
> 1 Web Tier Component Architecture
> 2 Building MapGuide Server and Web Extensions on Linux
> 3 Building MapGuide Server and Web Extensions on Windows
> 4 Configure Web Extensions on Apache/Linux
> 5 Configure Web Extensions on Windows/IIS
> 6 Server and Web Tier Debugging HOWTO (Windows and Linux)
> 7 Running and maintaining Server and Web Tier Unit Tests
> 8 Branches for FDO and MapGuide
> 9 Document Render Service HTTP APIs
> 10 Other: please specify
> This work is already in progress so please respond as soon as you can.
> Thanks
> Tom
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
