[mapguide-internals] Re: RFC91 Mapguide Error Codes
Zac Spitzer
zac.spitzer at gmail.com
Tue Apr 13 11:09:44 EDT 2010
just looking at this error message, the title which contains the
exception name is pretty all we need.
we could just make the H2 title contain the exception name?
http://localhost:8008/mapguide/mapagent/mapagent.fcgi?OPERATION=GETR1ESOURCECONTENT&VERSION=1.0.0&LOCALE=en&
CLIENTAGENT=MapGuide+Developer&RESOURCEID=Library%3A%2F%2FTest%2FSources%2FWorld.Featur1eSource&FORMAT=text%2Fxml
On 9 April 2010 14:18, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> is it feasible to include the new method in 2.2? otherwise if we just
> edit the resources file
> we could just return the existing string with an error code prefix (see below)
> I guess for the FDO ones, we would need FDO to adopt this as well
> and then just pass thru FDO error codes?
> also how do we propose to add them into
> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
> adopt a string format like
> MgClassNotFoundException = MG-S-001: The
> specified class was not found.
> anyone across what do other projects do?
> On 9 April 2010 14:04, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
>> Yes. I think it makes sense to have the property in MgException.
>> Regards,
>> Trevor
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> Sent: April 8, 2010 7:47 PM
>> To: mapguide-internals at lists.osgeo.org
>> Subject: [mapguide-internals] Re: RFC91 Mapguide Error Codes
>> Should MgException be modified to include an error code property? Or only for
>> certain subclasses?
>> - Jackie
>> View this message in context: http://n2.nabble.com/RFC91-Mapguide-Error-Codes-tp4874857p4874893.html
>> Sent from the MapGuide Internals mailing list archive at Nabble.com.
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
More information about the mapguide-internals
