[mapguide-internals] RE: PATCH: MgNullableProperty XML
	serialization fix
    Jackie Ng
    jumpinjackie at gmail.com
    Tue Apr 13 19:53:35 EDT 2010
If SELECTFEATURES is the only means through which this format can be
consumed, then I think an in-place update is fine, seeing (as you already
know) the operation hasn't worked properly in over 1.5 years.
- Jackie
View this message in context: http://n2.nabble.com/PATCH-MgNullableProperty-XML-serialization-fix-tp4896341p4899154.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
