[mapguide-internals] PHP 5.3 (Trac ticket #1290)
Bruce Dechant
bruce.dechant at autodesk.com
Thu Apr 15 11:27:25 EDT 2010
If you build PHP from source you can include the ISAPI module.
However, for 64bit it will fail with the default source from php.net - the version I submitted to SVN for MapGuide has the needed files to build the 64bit version too.
Also, you will notice that I included the 32bit and 64bit Windows binaries of PHP 5.3 in SVN as a short term solution until we move to FastCGI.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Thursday, April 15, 2010 8:44 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] PHP 5.3 (Trac ticket #1290)
I think Bruce said something about being able to compile the isapi
version manually, it just isn't distributed? We could go to FastCGI,
but that's a bit of work...
On 2010-04-15, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Okay, so I've come to learn that ISAPI support has been dropped in PHP 5.3,
> explaining the absence of a php5isapi.dll and why PHP is utterly broken in
> my installer builds (because they now reference a dll that no longer
> exists).
> So what is the proper IIS script mapping now?
> - Jackie
> http://n2.nabble.com/PHP-5-3-Trac-ticket-1290-tp4672067p4906659.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
