[mapguide-internals] repository sync issue?
Andreas Morf a.morf at fkl.ch
Mon Apr 19 08:36:50 EDT 2010
Hi all,
For my map application I reimplemented LoadMap.php of Fusion-Viewer in Java
for setting a filter on every layer during map load. This results in a
strange behaviour of mgserver/webtier: Sometimes (after a few minutes or
even hours) the following error showed up
javax.servlet.ServletException: A length exception occurred.
string too long
- MgLayerBase.GetLayerInfoFromDefinition() line 695 file
d:\development\mgdev_21\common\platformbase\MapLayer/LayerBase.cpp
org.osgeo.mapguide.MgLengthException: A length exception occurred.
string too long
	at
org.osgeo.mapguide.MapGuideJavaApiJNI.MgLayerBase_SetLayerDefinition(Native
Method)
	at
org.osgeo.mapguide.MgLayerBase.SetLayerDefinition(MgLayerBase.java:104)
	at ch.fkl.mg.fusion.LoadMapServlet.doGet(LoadMapServlet.java:316)
Concerning code is:
resourceService.SetResource(newLayerResId, layerDefContent, null);
layer.SetLayerDefinition(newLayerResId, resourceService);  // <--- line 316
where newLayerResId is a location in the session repository and
beforementioned commands are executed for every layer of a map.
The strange thing is that if inserting a "sleep(20);" between these
commands, everything seems ok - but this is not an elegant solution.
I can access the saved layer in the session repository with mapagent:
correct LayerDef-XML!
Also with the java webapi sometimes I get the following mgserver
errorlog-entry:
Error: An exception occurred in DB XML component.
        Please try your operation later as the repository was busy.
Any ideas about these issues or is java simply too fast for mgserver api?
Andreas
More information about the mapguide-internals mailing list
