Visual Studio Express Editions support? was: [mapguide-internals] Motion Vote: RFC 104 - Support Visual Studio 2010
Traian Stanev traian.stanev at autodesk.com
Tue Aug 3 11:25:28 EDT 2010
One thing that I could not make work with VCExpress 2010 was integrating the x64 compiler/tools into the IDE. The hacks that make this happen in 2008 are no longer applicable to 2010 since the registry entries that controlled them are no longer there. So the 64bit compiler has to be invoked manually.
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Tuesday, August 03, 2010 11:22 AM
To: mapguide-internals at lists.osgeo.org
Subject: Re: Visual Studio Express Editions support? was: [mapguide-internals] Motion Vote: RFC 104 - Support Visual Studio 2010
And this is to confirm that cross-compiling to 64-bit with vc express works
as well.
So unless Microsoft has done something drastically different with the VC++
2010 express edition, MapGuide should build with that express edition too.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Visual-Studio-Express-Editions-support-was-mapguide-internals-Motion-Vote-RFC-104-Support-Visual-Stu0-tp5327526p5368817.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
