AW: [mapguide-internals] DWFx support
Samuel Berger samuel.berger at icfm.ch
Thu Jan 7 14:54:33 EST 2010
That's what i feared... I'm unfortunately not a C++ programmer (one of the
lazy C# generation).
I just couldn't find any info on the internet/user-mailinglist, that's why
posted on the internal.
We do create our printouts bypassing MapGuide, getting our geometries
directly from DB and style it the same way. Because we need to rotate our
maps for situation plans (to rotate the maps hanging on wall as the viewer
looks at it) , some symbols like arrows need to rotate with the map and
informational symbols and text should not rotate.
As our special case is beyond MapGuide, our printouts need special treatment
anyway. My investigations on GeneratePrintout is due to data not originating
from our DB to include it in the printouts. But PNG will do. This may just
be useful info of what people are doing using MapGuide, as i saw some
discussion recently on enhancing print layout capabilities in MapGuide,
otherwise, just ignore it....
Thank you very much for your answer!
Sam
-----Ursprüngliche Nachricht-----
Von: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] Im Auftrag von Walt
Welton-Lair
Gesendet: Donnerstag, 7. Januar 2010 19:40
An: MapGuide Internals Mail List
Betreff: RE: [mapguide-internals] DWFx support
Someone would first need to verify that DWFx supports all the
MapGuide-specific behavior that was added for Whip 6.01.  If so , then the
DWF Toolkit library would need to be updated to the current version (7.6?),
and probably some server code will change.
How about you get involved as a MG OpenSource developer and take this on?
It sounds like a reasonable starter project.
Walt
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Samuel
Berger
Sent: Thursday, January 07, 2010 1:20 PM
To: 'MapGuide Internals Mail List'
Subject: AW: [mapguide-internals] Re: Stylization FTW
Would it be a big deal to support DWFx or is it mainly 'just changing a flag
in DWF Toolkit'?
I think it would add a big value to MapGuide to export DWGx (XPS)!
As the DWF-Viewer is abandoned, but the whole rendering code is still there,
XPS output could open new ways like nice printouts  or a Silverlight
client...
Sam
Welton-Lair
Gesendet: Donnerstag, 7. Januar 2010 18:50
Betreff: RE: [mapguide-internals] Re: Stylization FTW
GeneratePlot creates a version 6.01 DWF (effectively a zip) which contains
version 6.01 W2D/Whip resources.
Support for generating other versions of DWF, like DWFx, is not currently
available in MapGuide.
Walt
Berger
Sent: Thursday, January 07, 2010 12:08 PM
GeneratePlot delivers an ePlot in Whip 2D, whatever you set in MgDwfVersion
parameter, right? Is there a way to make GeneratePlot return a .dwfx (an
.xps in other words)? This way, everyone running Windows could watch the
plots out of the box....
Jason: as the geometry data in SymbolDefinition is very similar to XAML or
SVG, you could use Inkscape to draw your symbols and export  XAML or SVG, or
use Microsoft Expression Design and export it as XAML.
Sam
Welton-Lair
Gesendet: Donnerstag, 7. Januar 2010 07:10
For plot to DWF are you referring to the problem that when you open the DWF
and zoom in the quality is poor due to the generalization?  If so, the way
to improve the data resolution is to increase the DisplayDpi on the MgMap
used with GeneratePlot.  But... the published MgMap API doesn't let you set
this, nor does GeneratePlot have an override that let you override it.
The only other option I can think of (short of enhancing the API) is to use
the GetPlot HTTP API.  You can control nearly all aspects of the plot,
including the DisplayDpi.  See the Web Tier test pages under MappingService
/ GetPlot.
Walt
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Wednesday, January 06, 2010 11:34 PM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Re: Stylization FTW
Me too. It's really quite powerful.  Unfortunate that there's no
sketching tool available to actually draw the symbols yet, but towards
the end I was at the point that I could draw them in my head. Except
for the bloody arcs... SOHCAHTOA all over the place :)
I was generally using a space +-1mm on each axis, which seemed to work
OK for me especially when it came to figuring out map scale mapping.
Glad I work in metric :)  now I wish I could figure out how to plot to
dwf without the nasty generalization/stroking.
On 2010-01-06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
> I agree, it's looking very nice.
> I'm glad the enhanced stylization is seeing some action.
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Wednesday, January 06, 2010 10:58 PM
> To: mapguide-internals at lists.osgeo.org
> Subject: Re: [mapguide-internals] Stylization FTW
> Wow, that is one purty looking map. Good job!
> I notice the tooltips stay at the same position instead of following the
> mouse pointer (like the basic AJAX viewer). Is this default behaviour in
> Fusion?
> - Jackie
> Jason Birch wrote:
>> Thanks again for all the help on my stylization questions.  We're going
to
>> be officially launching a new version of NanaimoMap out of beta tomorrow
>> that makes extensive use of it:
>> Default theme:
>>   - Places of Interest  -> Image-based
>>   - Transportation  -> Linear: Sidewalks, Crosswalks, Bike Routes,
Bridges
>> Utilities theme:
>>   - Extensive use of point-based stylization in the Water, Sanitary, and
>> Storm layers
>> And probably others I can't remember.  You can launch the map here right
>> now:
>> http://maps.nanaimo.ca/nanaimomap/
>> And yes, I know there's a JS problem in the Utilities theme... haven't
>> been
>> able to figure it out.
>> When I get a few minutes to breathe, I'll be uploading all of the
>> hand-crafted utility symbols to the wiki.
>> Jason
>> mapguide-internals mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> http://n2.nabble.com/Stylization-FTW-tp4264399p4264792.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
