[mapguide-internals] SDK build profile
alucas alucas at svl.es
Thu Jan 7 15:33:05 EST 2010
Hello jackie,
Did you compile and try the sample AU application successfully?
Thanks.
Jackie Ng wrote:
> For context, check the following links:
> http://au.autodesk.com/?nd=class&session_id=5241
> http://code.google.com/p/georest
> There are clear cases where the source code under MgDev/Common (and
> possibly others) has uses outside of MapGuide (without server/web
> dependencies), yet looking at the source code from the above links, they
> all seem to be informally referencing bits and pieces from the MG source
> tree.
> It would be nice to have an additional build target that produces a
> package consisting of the headers, libs, and dlls from MgDev/Common and
> any of its dependencies (FDO, etc) in effect, creating a formal desktop
> SDK (http://trac.osgeo.org/mapguide/wiki/Future/DesktopSdk)
> Thoughts?
> - Jackie
View this message in context: http://n2.nabble.com/SDK-build-profile-tp4172986p4268617.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals mailing list
