[mapguide-internals] Please review RFC 103
Zac Spitzer
zac.spitzer at gmail.com
Tue Jul 13 23:18:30 EDT 2010
taking a step back for a second,
how does this relate to the upcoming changes in
RFC 98 - EPSG/SRID Code Upgrade
https://trac.osgeo.org/mapguide/wiki/MapGuideRfc98
>From the motivation section of RFC 103 "For example, user can define
an EPSG code
mapping to a WKT if this EPSG code is not supported by MapGuide's
coordinate system. "
z
On 14 July 2010 12:34, Jason Birch <jason at jasonbirch.com> wrote:
> I would suggest that this kind of request should require author access AND
> should not be available through the API at all when authoring is disabled in
> webconfig.ini. setDocument should require Administrator privileges.
> I am not a big fan of allowing public access to configuration documents,
> regardless of the seemingly innocuous nature of the information they
> contain.
> I guess the Fusion widget info calls access files outside of the repository.
> Are there any others?
> Jason
> On 13 July 2010 16:24, Tom Fukushima wrote:
>> Along with SetDocument, what kind of user would be allowed access to this
>> file? For example, since the RFC mentions the Studio user perhaps these
>> operations only be available to someone with Author (or above) privileges.
>> Do we need a way to set security on this document so that we can restrict
>> who can access it? I would hope not since that seems like overkill.
>> Are there any other operations in MGOS that are similar to this (i.e.,
>> access documents or information outside of the repository) in behavior?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
