[mapguide-internals] Small change in RFC 96 - QuickPlot solution for both Ajax and Fusion viewers
Jason Birch jason at jasonbirch.com
Thu Jul 22 04:52:25 EDT 2010
I'm not an ajax viewer user, but that makes a bunch of sense to me.
On 2010-07-22, Mars Wu <mars.wu at autodesk.com> wrote:
> Hi all,
> I am implementing RFC 96. And I'd like to raise a small change in that RFC.
> The original solution for Ajax Viewer is like following:
> In Aajx viewer, Quick Plot will be implemented as an "Invoke Script"
> command:
> *         A new function startQuickPlot will be implemented in
> ajaxmappane.templ to start Quick Plot logic by loading the main UI into the
> Task Pane. The main UI will share the template for Fusion viewer. The
> template is shared as "copy / paste" so that there is no dependencies
> between Ajax viewer and Fusion viewer.
> *         The preview dialog will also be implemented through Jx.Dialog.
> That means we need includes JxLib.js in Ajax viewer.
> *         The capture box will be drawn in the map through the built-in
> jsGraphic API.
> *         New event handlers will be attached to the map window to handle
> the capture box's drag / drop / rotate
> The new idea is: we don't implement it as an "Invoke Script" command.
> Instead, we replace the existing "Get Printable Page" command, just like we
> replace the "Print" widget for Fusion Viewer.
> What do you think?
> Thanks,
> Mars
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
