[mapguide-internals] Re: The coordinate system initialization failed
Tom Fukushima tom.fukushima at autodesk.com
Tue Jun 8 22:11:15 EDT 2010
Also try setting the NLSPATH variable to point to the fdo3.5 nls subdirectory in order to get better error messages.  So for example, if your fdo is at /usr/local/fdo-3.5.0 then set the NLSPATH to
/usr/local/fdo-3.5.0/nls/%N
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, June 08, 2010 8:05 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Re: The coordinate system initialization failed
On 9 June 2010 11:44, Eduardo Sereno <edu at gismedia.pt> wrote:
> I have done ldd -r to libPostGISProvider-3.5.0.so and
> libFdoPostgreSQL-3.5.0.so and none report any problem.
> I am no using Oracle... im using postgres is there any relation????
that error i have only seen with oracle issues, i think it's potentially a bug,
just try installing the oracle instant client
it's a beta afterall and this is the first release with oracle
included me thinks
http://www.oracle.com/technology/software/tech/oci/instantclient/index.html?rssid=rss_otn_soft
otherwise i have no other suggestions, so why not give it a whirl
z
> Best
> Edu
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-coordinate-system-initialization-failed-tp5150715p5156297.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
