[mapguide-internals] Re: The coordinate system initialization
failed
Zac Spitzer
zac.spitzer at gmail.com
Wed Jun 9 20:50:49 EDT 2010
i suggest re-posting over on fdo-users as this is a FDO specific issue
and the developers
who wrote this provider 'hang-out' over on that mailing list
z
On 9 June 2010 13:30, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Hi Edu,
> I did some checking into the postgresql libraries on Ubuntu 9.10. Ubuntu 9.10 uses postgresql 8.3 or 8.4. The FDO Provider was compiled on CentOS 5.4 against postgresql 8.1. It is possible that the version difference in the libraries on Ubuntu 9.10 may be causing the failure. If this is the case, then we may not be able to support postgresql on Ubuntu without native Ubuntu compilation. That would be disappointing.
> To the list - has anyone tried using the PostgreSQL or PostGIS providers on CentOS 5.4?
> Regards,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Eduardo Sereno
> Sent: June 8, 2010 7:45 PM
> To: mapguide-internals at lists.osgeo.org
> Subject: [mapguide-internals] Re: The coordinate system initialization failed
> I have done ldd -r to libPostGISProvider-3.5.0.so and
> libFdoPostgreSQL-3.5.0.so and none report any problem.
> I am no using Oracle... im using postgres is there any relation????
> Best
> Edu
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-coordinate-system-initialization-failed-tp5150715p5156297.html
> Sent from the MapGuide Internals mailing list archive at Nabble.com.
> mapguide-internals mailing list
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals
