[mapguide-internals] RFC Review - RFC 96: QuickPlot solution for both Ajax and Fusion viewers
Jason Birch jason at jasonbirch.com
Sun Jun 13 01:39:08 EDT 2010
You forgot the part about PDF support! :)
Seriously, I have a few questions:
- what is the output format for quickplot? I understand that the
preview window will show layout; is the output the same html+png as
the current print widget, but with higher dpi image?
- sounds like there may be a dependency between fusion and the ajax
viewer for this function. If so, please work to avoid this. These
viewers should be able to be individually removed from a production
install to limit attack surface area.
- I wonder if there is a way to shape this enhancement so that it
replaces the current print function instead of adding a new one? Maybe
have it open the task pane first, with optional area-select button,
title, dpi, and print button at bottom? Ideally, would allow selecting
sheet size, portrait/landscape, and format as well, but I know that's
stretching it a bit...
Jason
On 2010-06-12, Mars Wu <mars.wu at autodesk.com> wrote:
> Hi all,
> Could you help to review the new RFC here?
> https://trac.osgeo.org/mapguide/wiki/MapGuideRfc96
> Any comments are appreciated!
> Thanks,
> Mars
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
