[mapguide-internals] RFC Review - RFC 96: QuickPlot solution for
both Ajax and Fusion viewers
Jason Birch
jason at jasonbirch.com
Sun Jun 13 02:47:14 EDT 2010
If you change to advanced mode on my map
(http://maps.nanaimo.ca/nanaimomap/) you can see the way DMSG
implemented the save-as-dwf fusion widget. I wonder if giving options
html/png/jpg/dwf would be cramming too much into one widget/task.
On 2010-06-12, Mars Wu <mars.wu at autodesk.com> wrote:
> Hi Jason,
> Really thanks for your comments!
>>> - what is the output format for quickplot? I understand that the preview
>>> window will show layout; is the output the same html+png as the current
>>> print widget, but with higher dpi image?
> It's basically right. The output format is still HTML +png. And the picture
> has higher dpi
>>>- sounds like there may be a dependency between fusion and the ajax viewer
>>> for this function. If so, please work to avoid this. These viewers should
>>> be able to be individually removed from a production install to limit
>>> attack surface area.
> There will be no dependency between fusion and Ajax viewer. The "share"
> between Ajax and Fusion will be based on "idea" level. Maybe the code will
> be copied from Fusion to Ajax and has a small change to work in Ajax viewer.
> And also the "main UI" which is in the taskpane will "look" the same in Ajax
> and Fusion. (but the code is separated)
>>>- I wonder if there is a way to shape this enhancement so that it replaces
>>> the current print function instead of adding a new one? Maybe have it
>>> open the task pane first, with optional area-select button, title, dpi,
>>> and print button at bottom? Ideally, would allow selecting sheet size,
>>> portrait/landscape, and format as well, but I know that's stretching it a
>>> bit...
> "Replacing" the existing widget could be a good idea, it will remove
> confusion for the user, I like it... (I will update the RFC on this)
> About the "sheet size", it's also in the plan (I will update the RFC on
> this)
> About the "portrait/landscape", the "capture box" could be rotated. Then by
> default it's Landscape, if the user rotates it by 90, then it will be
> Portrait.
> About the format (I guess you are talking about PDF), it's not planned :)
> Thanks,
> Mars
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Sunday, June 13, 2010 1:39 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] RFC Review - RFC 96: QuickPlot solution
> for both Ajax and Fusion viewers
> You forgot the part about PDF support! :)
> Seriously, I have a few questions:
> for this function. If so, please work to avoid this. These viewers should be
> able to be individually removed from a production install to limit attack
> surface area.
> the current print function instead of adding a new one? Maybe have it open
> the task pane first, with optional area-select button, title, dpi, and print
> bit...
> Jason
>> Hi all,
>> Could you help to review the new RFC here?
>> https://trac.osgeo.org/mapguide/wiki/MapGuideRfc96
>> Any comments are appreciated!
>> Thanks,
>> Mars
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
