[mapguide-internals] Mapguide 2.2 beta PostGIS provider & PostgreSQL/PostGIS provider failure
Tom Fukushima tom.fukushima at autodesk.com
Thu Jun 17 14:51:52 EDT 2010
As Trevor replied, he is looking into the build issue so that's in good hands.
To answer your other question, the source is here: http://trac.osgeo.org/fdo/browser/branches/3.5/Providers/GenericRdbms/Src/PostGis
All the providers that are based off the GenericRdms framework are here:
Cheers
Tom
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Gabriele Monfardini
Sent: Thursday, June 17, 2010 9:45 AM
To: MapGuide Internals Mail List
Subject: [mapguide-internals] Mapguide 2.2 beta PostGIS provider & PostgreSQL/PostGIS provider failure
I'm on Centos 5.5 with Mapguide 2.2 Beta
When trying to create a dataconnection with both PostGIS provider and
PostgreSQL/PostGIS provider from Maestro (very recent version) I
obtain the infamous-and-way-too-generic
CLNT_8_UNABLE_TO_LOAD_LIBRARY
Doing an ldd on libFdoPostgreSQL-3.5.0.so, on
libPostGISProvider-3.5.0.so and on libPostGISOverrides-3.5.0.so I do
not have any missing library reference
The same happens to all referenced dynamic libraries, no one shows
missing references.
Thus I cannot find which library is missing
However it appears that neither libFdoPostgreSQL-3.5.0.so, nor
libPostGISProvider-3.5.0.so, nor libPostGISOverrides-3.5.0.so depends
on libpq (PostgreSQL library).
How is it possible?
Does anyone have ever tried those provider and connect correctly to postgreSQL?
Are those providers been built correctly?
Note that I'm using OGRProvider with a libgdal built with PostgreSQL
support and it is working quite satisfactorily (and obviously it
depends on libpq4.dll)
Another question:
If I'm correct, PostGIS provider is the old one while
PostgreSQL/PostGIS is the new one, developed by Autodesk, thus more
promising.
Why I cannot find it in
http://trac.osgeo.org/fdo/browser/branches/3.5/Providers?
Where is the source code?
Regars,
Gabriele Monfardini
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
