[mapguide-internals] RE: RFC Review - RFC 96: QuickPlot
solution for both Ajax and Fusion viewers
Ivan Miličević
Ivan.Milicevic at supranet.hr
Mon Jun 21 03:18:02 EDT 2010
That's too bad. Autodesk should be more flexibile here, I'm sure that they could find a way to share toolkit only to the mapguide users.
Thank's for the answer, when I develop such a function I wil provide it to the cummunity.
Thank's again.
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, June 21, 2010 9:11 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] RE: RFC Review - RFC 96: QuickPlot solution for both Ajax and Fusion viewers
The problem is strictly a licensing one.
Writing DWGs files requires the RealDWG toolkit, which is a proprietary SDK which is obviously incompatible with MapGuide Open Source.
That doesn't stop you from attempting such a solution yourself (if you have a RealDWG license), it's just not possible to integrate such functionality into an Open Source project.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/RFC-Review-RFC-96-QuickPlot-solution-for-both-Ajax-and-Fusion-viewers-tp5173317p5203146.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
