[mapguide-internals] Installer on Branch?
Trevor Wekel trevor_wekel at otxsystems.com
Wed Jun 23 18:03:40 EDT 2010
Hi Crispin,
I branched MapGuide 2.2 "MgDev" to open up trunk for new development work.  I did not branch "Installer" since the 2.2 installer is still a work in progress.  The build64.bat scripts are partially working for IIS/.Net.  IIS/PHP, Apache/PHP, and Apache/Tomcat/Java still need to be looked at.  Once the installer is fully working, I will branch it for MapGuide 2.2.
Regards,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Crispin_at_1Spatial
Sent: June 23, 2010 10:33 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Installer on Branch?
I am going through the process of creating a Win64 build from \Branch2.2
(some manual steps/hacks but seems reasonable - though maybe issues with
webapi - lots of noise from build64.bat).  But more another time.
This query is if the \Installer should branch at the same time as \MgDev as
there seem to be things that need to be kept in sync to re-create a
versioned redistributable?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Installer-on-Branch-tp5214092p5214092.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals mailing list
