[mapguide-internals] Potential for broken build on trunk - update
to Subversion 1.5
Trevor Wekel
trevor_wekel at otxsystems.com
Tue Mar 2 19:45:42 EST 2010
Hi everyone,
To support a local svn proxy for the build infrastructure I have modified the svn:externals declaration under Oem. Based on what I have read, it should work. However, you must be using Subversion/TortoiseSVN 1.5 or later to make use of the updated svn:externals declaration. Please see http://trac.osgeo.org/mapguide/ticket/1286 for details on the change.
Since Subversion 1.5.0 was released in June 2008, I assume that everyone is using a 1.5 or greater client by now. If you are not, please download one.
I am currently downloading the source to verify that the new svn:externals declaration is working correctly. I will post an update once the download and verification is complete.
Thank you,
Trevor
More information about the mapguide-internals
