[mapguide-internals] Compiling MapGuide Oem under GCC 4.4
Trevor Wekel
trevor_wekel at otxsystems.com
Wed Mar 3 16:16:31 EST 2010
Hello,
I've been attempting a MapGuide build under Ubuntu 9 with GCC 4.4. I have gotten part way through the Oem tree but am hitting lots of errors with Berkeley DB XML. I did a little checking and the BDB XML version (2.3.10) we are using was released in January 2007.
Since GCC 4.4 was released in April 2009, it is quite reasonable to expect that BDB XML 2.3.10 will simply not compile under GCC 4.4. Compilation with GCC 4.1 on Ubuntu 9 is also problematic due to hardcoded CC/CXX/etc declarations in some of the build scripts.
The only "easy" solution to produce binaries on Ubuntu is to the compile the binaries on CentOS 5 and copy them over to Ubuntu. This leads to issues with missing shared libraries which can be worked around with some careful symlinking. This works but it is not really a great solution.
Are we planning to update DBXML? Or should we consider deprecating part of the Oem tree on Linux (dbxml, PHP, LinuxApt) and simply move to compiling against the native "-dev" libraries?
Regards,
Trevor
More information about the mapguide-internals
