[mapguide-internals] ACE assertion failed
Gabriele Monfardini gabrimonfa at gmail.com
Mon Mar 15 13:48:41 EDT 2010
Hi all,
I'm using mapguide 2.1 on Debian Lenny with several concurrent users.
I've found several lines like this in
webserverextensions/apache2/logs/error_log.
ACE_ASSERT: file Configuration.cpp, line 1631 assertion failed for
'this->allocator_'.Aborting...
[Mon Mar 15 10:17:15 2010] [notice] child pid 6319 exit signal Aborted (6)
Sometimes it happened several times in a minute.
The referred file is here:
http://trac.osgeo.org/mapguide/browser/branches/2.1/MgDev/Oem/ACE/ACE_wrappers/ace/Configuration.cpp
The server appears to continue running after this error, but I'm not
sure since I'm also experiencing sporadic crashings.
I'm running with stock serverconfig.ini, httpd.conf and mapguide.conf.
Does anyone have any suggestions?
Regards,
Gabriele Monfardini
More information about the mapguide-internals mailing list
