[mapguide-internals] Re: 32 bit installer on build machine
Jason Birch
jason at jasonbirch.com
Mon Mar 22 19:03:17 EDT 2010
Sure, could do.
We should make sure to confirm with external projects (Fusion, FDO, CS-Map)
that we're referencing the correct revisions before we go beta.
Jason
On 22 March 2010 15:41, Trevor Wekel wrote:
> Yep. Figured some of that out already...
> call build.bat -source=%INSTALLROOT% -version=2.2.0.%REVISION%
> -name=MapGuideOpenSource-2.2.0.%REVISION%-Beta1 -title="MapGuide Open Source
> 2.2 Beta 1"
> So I think I will hack up updateversion.vbs script to simply take the build
> number on the command line. "svn info" doesn't work with export. Then we
> should be all set.
> Do you want me to post the installer on OSGeo downloads so you can try it
> out. So far, Apache/PHP and IIS/.Net both seem to be working.
> Thanks Jason (and Jackie),
> Trevor
More information about the mapguide-internals
