[mapguide-internals] Re: 32 bit installer on build machine
Paul Spencer
pspencer at dmsolutions.ca
Mon Mar 22 20:14:52 EDT 2010
Mike is very close to finalizing the 2.0 version of Fusion, I don't know if he is working from trunk or from the 2.0 branch but I would like it to be from the branch if it isn't already. I'll discuss with Mike tomorrow and make sure that's good with him.
Cheers
Paul
On 2010-03-22, at 7:03 PM, Jason Birch wrote:
> Sure, could do.
> We should make sure to confirm with external projects (Fusion, FDO, CS-Map)
> that we're referencing the correct revisions before we go beta.
> Jason
> On 22 March 2010 15:41, Trevor Wekel wrote:
>> Yep. Figured some of that out already...
>> call build.bat -source=%INSTALLROOT% -version=2.2.0.%REVISION%
>> -name=MapGuideOpenSource-2.2.0.%REVISION%-Beta1 -title="MapGuide Open Source
>> 2.2 Beta 1"
>> So I think I will hack up updateversion.vbs script to simply take the build
>> number on the command line. "svn info" doesn't work with export. Then we
>> should be all set.
>> Do you want me to post the installer on OSGeo downloads so you can try it
>> out. So far, Apache/PHP and IIS/.Net both seem to be working.
>> Thanks Jason (and Jackie),
>> Trevor
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Paul Spencer
Chief Technology Officer
DM Solutions Group Inc
http://research.dmsolutions.ca/
More information about the mapguide-internals
