[mapguide-internals] MapGuide 2.2 Beta Release Readiness
Bruce Dechant
bruce.dechant at autodesk.com
Tue Mar 23 11:50:50 EDT 2010
Jason,
You can build 64bit PHP from source and even the ISAPI module (with some trivial assemble work) - I have done both of these in the sandbox.
They should have bundled installers soon for 64bit, but ISAPI support has been dropped and so FastCGI is what we will need to move to eventually.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Monday, March 22, 2010 4:58 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] MapGuide 2.2 Beta Release Readiness
Yeah.
All kinda nightmares with a single bundled installer if we go that way. May
just have an x64 server install, and require users to download both 32bit
and 64bit installers if they want web extensions on the same machine. Ouch.
But I don't think that installing the 32bit web extensions from the 64bit
installer is something that is do-able. I wonder if we need to consider
splitting the server and web installers back out into separate downloads?
Looks like there is no 64bit PHP for Windows yet, and they have switched
from ISAPI to fastcgi, so we likely have limited options here.
Jason
On 22 March 2010 15:34, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
> Yep. That sounds right. Same would go for the mapagent. Each process
> space is either 32 or 64 bit. I haven't run the 64 bit builds yet so I
> don't know what portions of the Web Extensions / mapagent are getting built
> successfully.
> But it should be possible to run 32 bit Web Extensions against a 64 bit
> Server. This might be a quick and dirty approach...
> Sent: March 22, 2010 4:29 PM
> I'm not sure if any of the tools need updating, but I'm guessing that we
> wouldn't be able to run a 32bit PHP ISAPI client against 64bit MapGuide
> DLLs?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
