[mapguide-internals] MapGuide 2.2 Beta Release Readiness
Jason Birch
jason at jasonbirch.com
Wed Mar 24 00:39:39 EDT 2010
Part of the problem is that there is no x64 Apache for windows.
I've personally had no problems with IIS7, other than the initial
learning curve. It's way more like Apache in terms of speed,
reliability, and configuration.
If someone else wants to step up and create an Apache install that
works under x64, and ensure that the MG Apache module compiles and
runs within it, I don't mind building it into the installer.
Otherwise, it likely won't happen. You could still run a 32bit web
tier on a 64bit machine though. The server likely benefits more from
the extra bits anyway.
On 2010-03-23, Martin Morrison <martin.morrison at edsi.com> wrote:
> NO!!!!!!!
> Do the 64 bit Apache...<flamesuit on> that way some of us can have nice
> stable fast webservers...<flamesuit off>
> ________________________________________
> From: mapguide-internals-bounces at lists.osgeo.org
> [mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> [jason at jasonbirch.com]
> Sent: Tuesday, March 23, 2010 7:35 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MapGuide 2.2 Beta Release Readiness
> That sounds like a plan. Your idea of trivial and mine are likely orders of
> magnitude different though :) I don't have any problems bundling up PHP,
> but actually compiling it is a different question entirely... are the
> changes you had to make actually in the sandbox, and can they be ported to
> trunk?
> I personally think we should remain with the ISAPI module for the MapAgent
> as long as it compiles in 64bit.
> If we can get this together for IIS, I'm still of the mind that 64bit Apache
> option is likely not worth the trouble. Oh, and that perhaps we should
> restrict 64bit IIS to IIS7+?
> Jason
> On 23 March 2010 11:44, Bruce Dechant wrote:
>> Going forward PHP only officially supports FastCGI and has dropped ISAPI
>> support - for both 32bit and 64bit.
>> However, the code is still there and only required a trivial tweaking to
>> get the 64bit ISAPI module built so we could continue to use the ISAPI
>> module for 2.2 and move to FastCGI for 2.3
>> Thanks,
>> Bruce
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
