[mapguide-internals] Re: 32 bit installer on build machine
Trevor Wekel trevor_wekel at otxsystems.com
Wed Mar 24 10:51:55 EDT 2010
Hi Zac,
I do not believe we have considered side by side installation.  Taking a quick look at the installation image, there are few things we would have to change.  There might be more:
1. Install into OSGeo/MapGuide2.2 (or similar) instead of just OSGeo/MapGuide.
2. Registry settings for OSGeo/MapGuide (probably add version underneath)
3. Version specific virtual directory in IIS
4. MSI unique identifier (I'm guessing there is one?)
Jackie and Jason are the primary maintainers for the Windows installer and implementing these items could be a fair bit of work.  Time permitting, side by side is definitely a good feature.
Although I have not completed the Linux packaging for Ubuntu, the same issue would still apply unless we do some directory revisionsing, ie. /usr/local/mapguideopensource becomes /usr/local/mapguideopensource-2.2.  I will take a look at doing this for Linux.
Good thing I stuck that test build up there :)
Thanks Zac,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: March 24, 2010 3:40 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Re: 32 bit installer on build machine
any reason why can't install two versions, ie 2.1 and test 2.2 on the
same machine?
MapGuideOpenSource-2.2.0.4686-Test.exe wouldn't install
z
On 24 March 2010 15:43, Trevor Wekel <trevor_wekel at otxsystems.com> wrote:
>>"but my build server because your build machine does not build my features i want to test, so I >need the installer...."
> Are you working on additional enhancements to the MapGuide code base?  Do you need a sandbox?
>>in particular when deploying the testbuild to a different server for
>>load testing ....
> The build environment I have set up is flexible.  We can add more VMs.  vSphere 4.  dedicated 8 core box.  16GB of ram.  300GB RAID1 SAS disk.  All dedicated to MapGuide Open Source.  We can allocate up to four cores to each VM to make load testing more realistic.
> If your intent is just to do build validation on code checked into Subversion, we should move it to common infrastructure so the entire community can benefit from all the work you are doing.  We should also add databases with standardized data sets to the build/test environment.  Then we can write a few unit tests for the databases.  This will help ensure that the builds are solid.
> If you want your own VM to test new code out before submitting to Subversion, we can discuss that to.  Using a common build/test environment will help ensure that nobody breaks anything.  It will also allow us to set up a more complete environment.  I sure as heck don't want to maintain four different databases (SQL Server, MySQL, Oracle, PostGIS) just for myself.
> Software companies maintain testing infrastructure to benefit software developers.  We can do the same.
> Regards,
> Trevor
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the mapguide-internals mailing list
