[mapguide-internals] Re: 32 bit installer on build machine
Dave Wilson
dave.wilson at autodesk.com
Thu Mar 25 11:13:30 EDT 2010
We just resolved an issue with PHP, at least for IIS.
There are 2 settings that need to be set to be different from the prior install to avoid conflicts:
session.save_path and session.cookie_path in the php.ini. These need to be a directory that IIS can write to to create PHP sessions. We plan to implement /PHP/temp to address this. I would expect this is also an issue for PHP under Apache.
There is also still a dependency for IIS that an HKLM\software\PHP\version\ini_path variable be set in the registry. This means a 5.2.5 and 5.3.1 version can sit side by side.
Dave
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, March 25, 2010 7:06 AM
To: mapguide-internals at lists.osgeo.org
Subject: [mapguide-internals] Re: 32 bit installer on build machine
Oh and the Web API files are now under help\webapi, and the Viewer API is
under help\viewerapi
Which means a full wix file regeneration is needed.
- Jackie
View this message in context: http://n2.nabble.com/32-bit-installer-on-build-machine-tp4772724p4797451.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
mapguide-internals mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
