[mapguide-internals] 32 bit installer on build machine
Jason Birch jason at jasonbirch.com
Fri Mar 26 22:28:29 EDT 2010
I wonder if we need two installer paths, test and prod. Test includes
the docs, mapagent test pages, templates, schema viewer, is set to
allow authoring, full logging, default passwords and php errors on.
Prod tightens up based on secure install recommendations and, ideally,
prompts for passwords.
On 2010-03-26, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> One other option would be nice in the installer is to be able to
> set the php.ini display_errors=(on|off) to start with..
> I think this would really help people starting out, as the old
> silent failure with php is really confusing for a lot of people
> as can be seen on the mailing list
> thoughts?
> On 26 March 2010 13:00, Jason Birch <jason at jasonbirch.com> wrote:
>> ISAPI support has been dropped from PHP as of 5.3.  The code's apparently
>> still there (as per Bruce), but all reference to it is gone from the PHP
>> docs and FastCGI is now the only supported SAPI for PHP under IIS.
>> We moved away from FastCGI because of stability problems, and also because
>> it looked like it was dead in the water.  In the meantime, MS and PHP
>> (Zend?) got together and decided that FastCGI was the best way of making
>> PHP
>> work under Windows. MS updated FastCGI for Windows for IIS 5.1 and 6, and
>> built it into IIS7: http://www.iis.net/expand/FastCGI
>> I'm still convinced that a dedicated module is the best bet for MapGuide
>> core, but it seems that going back to FastCGI for PHP is necessary post-MG
>> 2.2.  We may eventually have to revisit this for the MapAgent as well
>> when/if MS drops ISAPI support in favour of new native IIS7 modules (
>> http://learn.iis.net/page.aspx/169/develop-a-native-cc-module-for-iis-7/)
>> Jason
>> On 25 March 2010 18:45, Jackie Ng wrote:
>>> Going back to FastCGI? Is it actually usable now unlike 3 years ago?
>>> - Jackie
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
More information about the mapguide-internals mailing list
